Why you need to do an EGR delete
#36
Since this contributes to idle motor failure, TB issues since thats the first place 1500* exhaust goes, knock, etc. it made sense to do a test and offer a product. This has been common knowledge since the DSM days that the EGR causes IAC issues. Almost all Evos are 75k anymore and when I saw an NA 2.4 with a bad EGR I thought how much more likely are the turbo ones to be bad.
We do lots of testing that almost no one sees nor ever pays for. Who played with 2150s before anyone, had a LR2.4 Evo, modded MIVEC cam gears, helped iron out bugs in SD, or did alpha testing for Tephra in Feb of 2007?
That is not the point. I test so I know what it does. Why we did the Auto in the DSM and then Evo, why my brother bought an RA and I bought a X MR, when its here in front of me 24/7 I learn. I could choose to never talk about what we do and then when someone else tests it I could say "hey I tested that 10 years ago and knew this", what would you think? I would think that person was an A-hole. While I keep some trade secrets a little closer, things like this are meant to be shared and show why we need to do them. Tunes dont change, idle problems are only going to progress, so this proactive to keep complaint phone calls minimized in at least one department.
You can make this yourself out of aluminum at home if you have the stuff to do it. IF you dont, you will need a grinder, some aluminum, probably a bench grinder, etc. Seems like that costs more than $25 to get setup. Or a waterjet if you want them to look like this.
#39
yes,hes a good man but i meant that ppl can make their own block off plate if they want to or they can buy it from vendors.thats all.
#40
I see both sides of this and thank both posters.
#41
FYI. If you live in MA and want an inspection sticker, do not delete EGR or EVAP. Even if you turn them off in ECUflash and "force pass", you will fail inspection.
Also, bench grinder + aluminum= bad
#44
You can make a fairly thin spacer to sit between the stock EGR valve and the manifold. The other option is pulling the intake off and tapping the manifold for a pipe plug and then remounting the EGR. Do a high boost boost leak test and see if you can hear it near the valve...not always easy to do.
