e_kobz's FP 71HTA stock block/head/cam Evo IX - 450/400 on E85 @ 31psi
#46
Depends on what's important to you. I have yet to find a DV/BOV that can deal with part throttle flutter/surge like the anti-surge cover, but in my experience there some loss in snappiness during offboost driving and in the transient rpms at the point where the motor is getting into the boost threshold.
#47
Yea i was thinking of doing dual maps for e85. But i drive the car alot so pump is a must. And if i find a double pumper for under 400 i think i will just on it. Might as well only upgrade once. Seller said it had a walbro but i cant just assume he was truthful. Also were the injector you were using high or low z injectors? Because i seen mrfred had some for sale.
#48
#51
Took the car on a little road trip yesterday up to Jerome and Sedona in Arizona. They're about 150 miles north of me. In order to get to them you have to drive through some gorgeous mountain roads and a ton of switch backs. I felt it was necessary to have just a little fun, like California canyon carving fun. The car felt amazing. I still can't believe how hard this little turbo hits and pulls. Going through the mountains on he way to Jerome and Sedona is all uphill, the car wasn't phased one bit. It also helped that the temperature was in the 30's all day. I'm am more and more blown away everytime I drive this car.
#53
S3's would be pointless on my setup. I don't want a peaky power band nor do I ever plan on revving that high. My car is setup for a road course, not a drag strip. It would also be pointless on a non-ported head as it stops flowing at 11.2mm and the S3's have 11.5ex/11.7in of lift. S2's will be perfect.
#54
Well if you need one let me know, we can just meet up. PM me. And a double pumper will be over kill for 400whp on pump gas, a Wally 255 will net you that just fine. And yeah they're aren't too many E85 stations in the valley. I live down in south Gilbert and was driving 25 miles one way to the Valero in Scottsdale for E85. Fortunately Valero just opened up a brand new gas station a mile and a half from me and it has E85. I was ecstatic when I found that out. But the three closest E85 stations to me and probably you are the Valero that I use which is on Higley and Pecos, the Cobblestone on Elliot just off the I-10, and the Valero on Scottsdale Rd and McKellips
#56
Very nice numbers mate I'd like to see her run with a Bosch 044 fuel pump and some id2000 injectors to make it a little less scary I ran a walbro on e85 they are so close to the limit I'd hate to see her run dry, but very nice considering your mods love it
#58
Bare with me I'll get my old dyno results I might have done the work for you the biggest problem when Ihad my walbro and id1100cc injectors was i that my injector duty cycle was 98% at a fairly mild tune at 24psi we couldn't push it harder not enough fuel with the I'd 2000cc we pushed it hard as we felt comfortable at 24psi and they were only at 67% duty cycle basically heaps of room for further go fast bits and the fact your fuel system is not working hard at all to produce the numbers you want
#59
