FP ZERO 803HP/644TQ Crispeed Tuned built by AG Autosports
It's been a long time coming but well worth the wait. I've been a loyal FP customer since 2008. I've run the first gen FP RED, 80mm FP RED, JB FP BLACK, BB FP BLACK and now the new FP ZERO. This turbo is a monster and I cannot wait to test it at the track. The dynograph shows a comparison of both turbos with just the turbo swap. The FP BLACK pull was done on 3/4/15 and the FP ZERO pulls were done on 3/6/15. As you can see over 100hp difference with just the swap. The guys at AG Autosports and my tuner Crispeed deserve all the credit.
Is this a 2.0? 47psi is a ton of boost! Did you compare at the same 42psi for both? I assume they won't be too far apart if nothing changed on the motor besides turbos.
ant_turbo (Sep 23, 2019)
These are the best I can do. Time was not on our side so did not have time to do an actual same boost comparison.
Rpm pickup issues for the dyno was also a problem.
Black is blue line
Zero is red line.
Black is blue line
Zero is red line.
