Efr 7670 iwg Full race top mount on a stock block with Mr 6 speed
#61
Had a little down time with the car. I got a powder coated valve cover from evodan2004. He removed the baffling and tapped it for screws.
We got the 5 speed and the twin disk in. Put some miles on it before we hit the dyno with the haltech ps1k ecu. Durring tuning we found some issues. I had the original wally 450 fuel pump. This pump had a 70 psi relief. Quick math 43 base plus 30 psi of boost made a headache with tuning. Also we had trouble with boost control. Adding 1 % made it hit 32 psi. Found that the wastegate had the wrong amount of preset. Fix it and mad the car a bit easier to deal with. The car now has full flex fuel capabilities and makes 500. This coming year will see just how much the 7670 is capable of.
#63
Also, interesting that you chewed up two 6-speeds. Our power levels and driving style sound similar, and I'm still doing fine on original 6-speed.
#64
Did you ever get a chance to get the Skunk2 installed, and if yes, were you able to get a feel for before/after dyno numbers?
FS[SouthEast]: BW EFR 7670 IWG with T4 twin scroll .92ar turbine housing.
black E
May 4, 2016 03:43 AM
black E
Apr 30, 2016 01:49 PM
flyingscot
19
Feb 4, 2015 02:19 PM
