Jeff's Evo IX Stock block ATP GTX3582R (Stock Frame) GSC S2 Map Rev3 91oct & E85
Finished Jeff's Healthy Evo IX up. It's still on the stock block, so we had to be careful with the torque curve as always.
I have been working with Jeff for about 2 years now, and we have had the car around this power level since then. So far so good.
The fuel being used is 91oct and E85. The graph displays which fuel is doing what.
The turbo on Jeff's car is one that most do not use or have much data on. It is an ATP Garrett GTX3582R (Stock Frame turbo).
The mods on the car are as follows:
Stock Block (76K)
GSC S2 cams
turbosmart raceport bov
MAP Rev 3 intake mani /w Full Blown 70mm
MAP Long Runner Stock frame manifold
FIC 2150cc injectors (56% IDC @ 11.6 afr)
Buschur Double pumper
invidia o2 housing and down pipe
tomei titanium test pipe and titanium cat back
sparktech non cdi ignition
ETS 3.5" FMIC /w upper & lower piping
4" SD intake pipe
Grimmspeed 3 port
Tephra v7 speed density /w ecuboost
Graph:
Pic of car:
Stock Block (76K)
GSC S2 cams
4" SD intake pipe
Grimmspeed 3 port
Graph:
Pic of car:
nice sleeper. i'm pretty curious about these turbos now that they are one of the few bolt-on ts turbos out there, so nice to see this. looks like reasonable good power for the boost level. did it take more wgdc than anticipated to hold that boost level?
i'd love to see the atp gtx3076 on a car with a good parts selection like this one.
Awesome numbers! FBO stock block 600whp, wow! (do you think 600whp/400tq is safe on a stock block?)
I have been very curious about this turbo as I am looking for a good mhi FP RED replacement/equivalent. Could you shed some light as to how this turbo/set up felt on the street as it's hard to gauge the actual response/performance based on your posted dyno since it looks like you started the pull at a high rpm. From the research I've done it seems that these atp turbos are a little laggy?
This is equiv to an FP Black, but a twinscroll FP black will spool much quicker also.
yes we have a few. Its pretty standard though.
Its using an Exedy triple HD I believe. Transmission is a TRE i believe.
tscompusa
Mar 5, 2016 03:15 AM
tscompusa
Jun 24, 2015 03:39 AM
Soshinoya
May 22, 2015 06:10 PM
tscompusa
Oct 16, 2014 03:25 PM
flyin_banana
Jul 16, 2014 11:05 AM
