Neal's Built 2.0L FP Zero GSC S2 MAP Rev3 93oct + meth results
I wanted to share Neal's results on his 93oct and 610cc of meth/water injection tune.
I know others want to see more feedback on the stock frame new line up of FP turbos.
Here's another FP Zero bolted onto a low/mid compression 2.0L engine
Temps outside were roughly 53F during the tuning.
Mods are:
Built 2.0L 9:1 wiseco/manley
CBRE ported head /w 1mm over valves
GSC S2 cams
FP Zero Turbo (SS housing)
STM downpipe/3in exhaust/ no cat.
MAP rev 3 intake manifold /w Full Blown 70mm
Muse UICP
ETS LICP V2.
ETS 4" intercooler
Buschur double pumper
FIC 1100cc inj (81.6% IDC @ 11.6 AFR)
6an fuel feed from rail to stock hardline.
Devilsown meth injection kit. 50/50 meth/water 610cc
Grimmspeed EBCS + hallman pro in cabin mbc.
spoolinup non cdi
Tephra v7 speed density /w hybrid 2 stage boost control
Graph attached has two 3rd gear pulls - low & high boost. One 4th gear pull to show the vehicle with the gearing it needs to take advantage of the FP Zero, which you can see resulted in higher power due to the vehicle having time to load up and build momentum from the torque.
Sometime in future we will put the FiTronic on this car and make some custom mixed ethanol blends so he can run straight injection instead of a nozzle before the plenum which most know is sketchy at times due to the cylinders not seeing the same mixture 100% evenly across.
Car went 11.14 @ 128.7 with more in it.
Mods are:
GSC S2 cams
Muse UICP
ETS LICP V2.
ETS 4" intercooler
spoolinup non cdi
Mods are:
GSC S2 cams
Muse UICP
ETS LICP V2.
ETS 4" intercooler
spoolinup non cdi
Mods are:
GSC S2 cams
Muse UICP
ETS LICP V2.
ETS 4" intercooler
spoolinup non cdi
Neal already got his car to the 1/4. (Something I need to do with my silver evo soon)
Temps were 20F hotter then tuning night, and still running the same trim/weight/ everything vs tuning.
So vehicle was putting down roughly 520whp ish in 4th gear & 460whp ish in 3rd and came back with this slip (left lane).
Video of pass:
http://www.facebook.com/brad.alexand...type=2&theater
Video of pass:
Before my engine decided to disintegrate I made 448hp @2 bar and I have a cnc'd head, throttle, R2 cams with a stock bottom end.
So in no way does it even resemble this turbo
Ya I can only do so much with what im given. This cars basically on 93oct with a little bit of meth/water. Im not trying to lean on the meth/water either to the point where the car becomes dangerous without the meth/water.
We still take advantage of its cooling properties, but we dont go nuts or anything.
I believe were gonna put FiTRONIC on this car in the near future so we will have some real nice numbers and track times.
I am not a fan of meth injection unless its injected directly into each runner individually. There's to many things going on when its sprayed pre throttle body. I cant have complete confidence each cyl is seeing the same amount of atomization
Physics dictate that it is not possible for each cylinder to get the same exact amount of meth. The only way to make sure of that is to have one injector installed on each inlet manifold runner.
I have no idea of how much you pushed the above specific setup but I am pretty sure that it has a lot more in it as it seems like one composed well. The numbers give me the impression that you have been pretty conservative in your tune and judging from other work you have done so far I am also sure you can get more out of it.
Marios
Marios
Marios
Marios
The 3rd gear isn't long enough to load the turbo/car up, so it lacks power, but 4th gear clearly shows the power curve.
4th gear it produced 548whp. 3rd gear 481whp.
It was 20F hotter during the 1/4 passes and the car did about a 127 trap. So 520whp in 4th, 460whp in 3rd that 127 trap is dead on the money.
More displacement always spools a turbo quicker. Its only using 81% injectors that's why. Its not necessary at the moment. It will be mandatory if he does E85 though.
Its only 610cc of meth/water. No ones getting more power out of here safely more then what is pushed out right now.
Although I did not read the thread correctly and was with the idea that the setup was on E85 hence my comment of low power, with 610cc of meth/water injector you should be around 95-96 oct which is like our 100oct ron over here, or was that is, cause we don't get it anymore. I would expect the fp zero, a turbo which is like an fp hta86, on this setup to be 540-550 whp on a mustang dyno such as Buschur's not on VD.
I am familiar with dynos and dyno loading, for sure 4th's gearing loads the car more than the third's, hence whenever I used dynos, the car was dynoed on fourth.
Do not get me wrong about my commenting, but it is kind of strange to me to see the specific results as I expected a bit more even with 93oct+ 610cc water/meth, around 50hp more on VD to be more precise. I run a similar to the above setup, self built and tuned, but on an fp black, and when I tested the car on the road consistently with various other setups, among them were setups such as a 2.3L fully built block+head gtx3076 with tial 1.06 housing,motec etc, and 2.0L fully gtx3582r builts, stock frame and externally gated respectively, none has beaten my own, hence why I also expected the fp zero to give more power. I have not dynoed the car with the last changes I made, but based on my experience in tuning and motorsport and on the results I got on the road, I would say the car is putting down 530-540 whp on a Buschur's dyno.
Marios
