TSComptuned 2.2 Super LR - ETS T3 6466 S3 cams AMS VSR 93oct 28-29psi
1996 Evo 4 TSComptuned 2.2 Super LR - ETS T3 6466 S3 cams AMS VSR 93oct 28-29psi
Just a little teaser of what my friend/customers Evo 4 did over in pakistan on 93oct with our built engine on a very conservative tune. Outside temps around 85F
Quick specs are:
TSComptuned 2.2LR (4g64 / 159MM Length rods)
TSComptuned Cylinder head
GSC S3 cams
ETS T3 turbo kit (standard placement)
PTE 6466 Turbo @ (28-29psi)
FIC 1450cc inj (71% IDC)
Dual walbro 255 modded
AMS VSR Intake manifold /w Works Engineering 70mm TB
Tephra v7 SD /w 2 stage ecu boost control
We are upgrading injectors, and switching to FiTronic. More results will follow later after this system is installed.
Highest pull we did on 93 was 620whp. We dialed the car down to a more conservative 570 for a final result for the time being, which I'm sharing.
Graph below:
Cool pics during engine assembly & album linked below:
Full album on FB: https://www.facebook.com/media/set/?...7302897&type=3
Quick specs are:
GSC S3 cams
Graph below:
tscompusa
May 9, 2013 08:45 PM
