Evo 8 stock block Fp Htz Green SS housing
Evo 8 stock block
Fp Green Htz SS housing
Speed density tune on e85
1450cc low z injectors
Walbro 450 dual voltage rewire
Hks 272 cams
3" turbo back exhaust with fp manifold
Competition clutch stage 3
Vrsf 3.5" intercooler with Ets short route piping
Tial q bov
First here's a shot of a datalogs to show psi and rpms
Started pull at 2900 rpm. Reached 23.7 psi at 4000 rpm, full boost (31psi) at 4400 rpm
Here's a Virtual Dyno chart of the datalog above which Isn't a smooth graph so I included a run that was at 2 psi less boost and was at lower timing.
Here's a dyno graph at smoothing 1 of the lower boost/timing run above. As I said the blue line wasn't a good run as it varies nearly 20 hp from smoothing 1 to 6.
Hks 272 cams
Tial q bov
The following 2 users liked this post by nickelndime:
pangyau (Sep 18, 2017),
Steveevoix (Nov 18, 2017)
vmrevo9 (Mar 3, 2018)
Yes 3,000 rpm is too early if your looking for the car to start pulling right away. I'd say 3500-4000 rpms is a better starting point to get boost response right away.
That's interesting. Looks very similar to my MHI red. But car is still fairly punchy (it's not in boost, but it doesn't feel completely dead either) in the 3000-3500 range in gears 1-3, so it's still fun on the streets.
EvoIX89 (Dec 4, 2017)
Eh, it looks really close to what I was able to push my car to before backing it off to keep the rods inside the motor. If he had the same cams we could make a better comparison.
I basically created this thread to show results to a few people that didn't believe my comments in another thread. Hopefully it'll help others that want to see some ss housing results.
"Response is amazing, and lag is almost not noticeable." I'm not sure the OP can make the same statement.
I appreciate you having an open mind and looking at the results instead of coming in biased like Erik seems to on every SS housing thread. I thought the numbers seem up to par with most mhi reds on stock block, especially since I only have the hks 272s. Also in these graphs im only running 26-28 psi up top.
But all that matters is if you like it. From everything I've seen, an FP Red can make 650whp on the SS housing. But I don't know if I'd care about that 50whp if I lost the responsiveness of the MHI housing.
Looking forward to more HTZ Green/FP 57 turbo dyno plots and VD charts
This is your remarks about your Red when you put the stock FD on.
Hey, I'm not trying to be a hater. And like I said before, I hope you're happy. If the single scroll lost a marginal amount of spool and made crazy power, I'd understand the trade off. But it looks like you lost 800 rpms of spool (Green typically spools at 4000 rpms on a 2.0) and a decent amount of responsiveness.
I failed to mention it's a journal bearing so I'm sure that combined with the SS housing it might give up some transient response to a Mhi Red. When I purchased the SS Green it was half the price of a JB Mhi Red, so with my budget I was happy to loose a little transient response to get Mhi Red power and spool.
THe JB HTZ Green is $1099. The JB FP 57 is $1699 with an MHI housing. I like your rounding.
Are you sure you don't want to pay $3,000 for an HTZ BB Red with a Xona center section and a ported to hell hotside with all the coatings? LOLOL
I don't think I'm a big bang for the buck guy. I'm a "Here, take my money kinda guy"
So, this is the HTZ Green with 67mm turbine?
If I had the funds then no doubt, Im sure I could find a way to spend it but this turbo fit the budget. Heck It took me 13 years before I could afford purchasing the Evo lol.
