Stock Block FP Red (SS) Kelford 272 93oct 28psi (3port vs MBC comparison inside)
Old Jul 8, 2017, 10:08 AM
tscompusa's Avatar
Originally Posted by dookgvr4
Why not hybrid boost?
No need for this setup its on stock block still.
Originally Posted by 4b11slayer
I have similar set up except i have s2s and its on e85 and still on a maf.
Makes 520 on virtual dyno at 30 psi.
I should go sd huh
MAF robs a ton of power with larger turbos. I rarely tune Evo's on MAF anymore. Most customers want SD.
Give me this same setup with E85 and S2's i can assure you around 600whp depending on weather conditions outside.
4b11slayer (Jul 8, 2017)
Old Jul 8, 2017, 11:07 AM
4b11slayer's Avatar
Tscomp cam you do this via email?
Old Jul 9, 2017, 06:39 AM
845evo9's Avatar
Nice @4b11slayer
Old Jul 10, 2017, 08:16 AM
tscompusa's Avatar
This car was done via email / internet based.
This car races tons of cars in its area and usually wins also. Even cars with bigger setups and on E85 while this vehicle is still only on 93 octane.
Old Jul 10, 2017, 06:06 PM
hatersGONNAhate's Avatar
if anyone wants to see some action of the car my instagram is 2ND W1F3
Old Jul 30, 2017, 12:00 AM
Yugi19911's Avatar
How many rpms is the limit with 272? 7800rpms? And what fuel do you use to produce 500+ horses with stock engine?
Old Jul 30, 2017, 03:20 AM
i don't remember the exact rpm but I've been taking it to about 8k on the street. The power doesn't drop off at all. As far as fuel, I'm still on pump gas 93
Old Aug 4, 2017, 10:26 PM
tscompusa's Avatar
Didn't mean to post in here yet, but now that I did, we will share the hybrid boost results sometime next week in here. It shouldn't really change much, maybe a little more aggressive spool characteristics, and come in less soft down low. This car has some 3 port flutter also, which the mbc will eliminate as well.
dookgvr4 (Aug 7, 2017)
Old Sep 7, 2017, 03:06 PM
dookgvr4's Avatar
Any updates?
Old Sep 7, 2017, 08:58 PM
tscompusa's Avatar
Any updates?
We haven't retuned it yet. The car runs other cars locally In NY with full built engines, more power, and e85 and still wins 9/10 races though and hes still on 93.
Old Sep 8, 2017, 08:41 PM
dookgvr4's Avatar
Ya I've been in the car, at first I found it hard to believe it was really only 93. Top end is unreal for 93 octane and a Red.
And quite honestly, I didn't notice it too be all that much laggier than my car. Although dyno graph May Say otherwise.
Old Oct 18, 2017, 07:31 AM
Recently put the car on e85. Stock block 138k
Mods stayed the same other then fuel upgrades, which includes
Fuel lab regulator
Walbro 450 rewired
Drilled siphon
FID2000cc
I was the only person in the car at the time of tune!!
Car trapped 132mph
Old Oct 18, 2017, 07:58 AM
Eric SlowEvo8's Avatar
well damn what's max hp on a red? my car came 2.4 fp red at 564 I was told but I think with better ic and 2000cc, spool up and retune I can max out turbo
GOOD NUMBERS!
Old Oct 26, 2017, 07:40 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
The red can be pushed to 650ish with a good setup and proper tuning.
Old Oct 26, 2017, 08:00 AM
I make 564 e85 2.4 on maf that's how the car came ill be going sd soon with 4 inch ic and spool up and see how we do unless red sells I'm going bigger
Quick Reply: Stock Block FP Red (SS) Kelford 272 93oct 28psi (3port vs MBC comparison inside)
