gsc s3
Old Jun 9, 2017, 09:54 AM
Highbooost's Avatar
gsc s3
can you run gsc s3 with stock valve springs
Old Jun 9, 2017, 09:57 AM
asuarez's Avatar
You can but you shouldn't. Buy Springs and retainers.
Old Jun 9, 2017, 10:01 AM
e_kobz's Avatar
No, they require an upgraded spring due to the added lift of the cam lobe
Old Jun 9, 2017, 10:04 AM
e_kobz's Avatar
You most definitely cannot run them with stock valve springs. Anyone who does is dumb and is cutting serious corners and playing with fire so to speak. The S3's have too much lift for the stock valve spring. GSC S2's can be ran on stock valve springs if the car is kept within the stock rev range. And the stock retainers are fine for any cam you put in the car. Definitely do not NEED retainers. A good set of beehive valve springs will be just fine.
Old Jun 9, 2017, 10:23 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Absolutely can not. Springs and retainers are required for S3's.
Per GSC, the stock retainer is only good to 11.2mm of lift before it starts hitting the valve seal.
https://www.power-division.com/gsc-p...r-evo-8-9.html
JohnBradley (Jun 13, 2017)
Old Jun 9, 2017, 10:27 AM
e_kobz's Avatar
Hmmmm I haven't seen that. My buddy with a stock block IX making over 600whp is using S3's with the stock retainers and he hasn't had any issues
Old Jun 9, 2017, 03:16 PM
dookgvr4's Avatar
He is playing with fire so to speak
Old Jun 9, 2017, 06:55 PM
4G63_EVO's Avatar
Absolutely not! S1 is the only one you should run with stock springs and by should I mean its possible but you shouldnt.
Old Jun 9, 2017, 09:45 PM
dookgvr4's Avatar
One other take away from that link is that they only reccomend a peak rev of 8200rpm and a peak boost of 25psi
I wonder if that is due to factory retainers? Or the springs themselves.....
Old Jun 10, 2017, 10:56 PM
mines5's Avatar
My buddy was doing the same thing ... 1 day his luck ran out.
Old Jun 10, 2017, 11:14 PM
e_kobz's Avatar
I'll give him a heads up then
Old Jun 12, 2017, 07:47 AM
The factory aluminum retainer is lighter weight than a Ti retainer. So the spring is what is limiting RPM and boost with a certain camshaft profile.
Old Jun 12, 2017, 12:32 PM
evo8vz's Avatar
Seen s3 run and not break with out spring
i wouldnt do it but its possible
Old Jun 12, 2017, 03:47 PM
Fernan 4G63's Avatar
I would invest in a set of Kiggly beehive or GSC HP springs and retainers. The last thing you want is to cheap out and have a spring crack, drop a valve and wreak havoc in there.
Old Jun 26, 2017, 05:16 AM
2winscroll's Avatar
Please read the sticky about posting in this section, its for dyno results only, please post in engine / drivetrain.
Quick Reply: gsc s3
