Stock Block HKS 7460GTII 91oct 23-24psi
ah really? Damn thats a bummer. If mine ever does fail i was planning on picking up another. Guess ill have to plan for other options.
HKS, and a number of owners, claim better than stock spool /shrug https://www.hks-power.co.jp/en/produ...turbo/db/12542
Its not a bad little turbo, and they rarely get shared, that's why I shared it. This one probably needs the WGA preloaded more or something of that nature. I was more impressed with its peak #'s on 91oct then anything thats why I decided to share to give some old school mixed results.
I like to share cars based on their setup. If i feel like others will enjoy seeing it ill share it. I have a stock turbo result ill share soon also that made decent power on low octane with meth.
This car was averaging about 20psi by 3600RPM in 3rd.
(EDIT: I may be wrong and this car in particular I shared has the defective WG flapper issue)
Typical rule of thumb is if a turbos bigger its going to spool a little later. (However I'm not saying better aero in a lighter billet wheel design cannot break this rule though).
There was a combination of issues with the first gen that added together to cause the wastegate flapper to fail. They changed the metallurgy of the flapper on the revised "Kai" version. I have one of the original versions that came with the cams. So far i have not had any issues with the flapper, but I don't track it, and I check/adjust the actuator preload on occasion. Its been like 70k miles and like 6 or 7 years of Daily since I installed it.
I dug up another car I did on the 7460GT II that does have a pretty nice spool Im sharing the logs below:
This one was a 2007 evo ix EDM back in 2012 I did (bc 272 cams). This is also 93 octane fuel.
This was in bar format in the log:
So this one here must of had a WG issue I shared.
One thing to note though this was done in march where its much colder outside, which will improve spool extremely.
Found one more back in 2011 on 93oct:
Seems to me the average these are doing is 20psi by 3200 when starting pull at 2500RPM in 3rd, and around 25psi by 3500RPM.
Not to say these arent having the WGA issues also. I've done about 20 of these 7460GT2's and averaging the results pretty much.
I know back in the day people had to cut their actuator rods shorter also or it wouldn't even spool right, so these results are all over the place due to a various reasons.
This is the fastest stock turbo i could find spool on my computer with a quick search:
Mods on this car are: 90 octane + meth
Full 3" TBE
ported aftermarket O2 housing
3.5" FMIC
upper/lower pipe (stock recirc BOV)
3" intake pipe k&n filter
Grimmspeed 3 port
Ported stock intake mani / exhaust mani / tb
kelford 272 cams
alcohol/water injection 50/50 /w torco additive to gasoline
Also note it has quite large cams for a stock turbo! stock cams will make it spool even quicker.
Raw data: (3rd gear) - graph from above
Full 3" TBE
3.5" FMIC
Grimmspeed 3 port
kelford 272 cams
