Stock Motor, ETS V Band 6466, Speed Density, 93 / e85
#32
A rwd car that may still be spinning at the 1/8 is different from our cars.
#34
Right.... High HP rwd car's on street tires can spin the tires to half track is what I was saying, which much more greatly effects mph than spinning in the first 200-300'. Also, our cars still accelerate pretty hard, even when the tires are spinning compared to a rwd car.
#36
It can have an effect a few mph here and there but I am more concerned about your lockout. Especially if it happens going into 4th. This will present a problem in attaining proper mph on your pass. If you can't get into top gear soon enough properly your speed will be low.
#37
Just wanted to update. We installed a buschur double pumper with twin walbro 450 pumps, solid motor mounts, and the new aem air fuel / ethanol gauge with the flex fuel sensor.
Upped the boost just a little. Made 607whp / 417ft lbs on E80!
Taking back to 1/4 mile this saturday to see how it does. Car will now be on a set of hoosiers. We adjusted the launch control map as well. Hoping it goes smooth!
