2.4 set up and hp numbers
new to the stoker worlds. all my other evos have been 2.0s this is the first one I get with a stoker motor 2.4
anything crazy about them aside from faster spool and less rev?
I got a 6262 bb going on and wondering what hp levels are good to stay around on a stroker motor, its a evo d stage 2 and will have 2150s, double pumper, bcs 272s already has and 4.5 intercooer.
What crank, rods and pistons are in it? What was piston to wall clearance set to?
this stage 2 2.4
https://www.evodynamics.com/products...4-short-blocks
email says main bearing clearance .0016 if that's what ur asking about?
piston weight 301.8g
rod weight 692.4g
ring 1 gap .018
ring 2 gap .021
bearing clearance .0019
ronaldo9 (Oct 31, 2017)
Any head work?
GSC R2's and S3's are the **** for the 2.4L's.
And if you want to extract every ounce of power from your set-up, then a billet JMF drag intake or a Magnus intake will help the big block breath in the higher rpms.
LR2.4L's can spin up to 8,500rpms.
2.4L 4G64's are not considered strokers.
A) 4G64 stroker = stroke > 100mm
B) 4G64 destroker = stroke < than 100mm
Those bearing clearance are on the tight side. Piston to wall clearance is the difference in size between the piston and the bore, it allows the piston to grow with heat. You spec this based on your expected power level when building the engine.
You also need to find out what wrist pins are in it. Standard .200 wall pins have a limit.
Vegeta_Ra
Nov 5, 2014 11:15 AM
Boost Solutions
Apr 21, 2004 08:05 AM
