Stock block ef4 generating super low numbers
Hey everyone I have recently swapped from my stock Evo 8.5 turbo to a MAP EF4 in hopes of close to 500whp that was somewhat safe on the stock drive train. When I first ran the turbo it was at wastegate pressure or roughly 15psi. This generated a evoscan horsepower of roughly 284whp 250wtq. I have since upped the boost searching for more power and am currently at 31 psi. At 31 psi I started to see slight knock so I have back off to 30 psi and removed a degree of timing. Afr is 11.5 at peak torque and goes to 11.1 at redline. The problem I am seeing is the car is struggling to make 400whp with 30 psi on a ef4. This does not seem correct given the size of the turbo. Compression test was all around 145 or so and boost leak confirmed bo severe boost leaks, one super small once at the iac valve and the boss screw which will be fixed soon. Blow off valve is holding strong to 35 plus. What do you folks out there could be the issue here, am I seeing valve float which is hindering the engine from producing more power? Mods list that are important to this are below.
Walbro 255hp
Pte 1050cc injectors
Full 3 inch turbo back
Walbro 255hp
Hallman pro boost controller
MAP EF4 with turbosmart wastegate 10.5 housing with eBay o2 housing
Kelford 272 on stock springs
Omni 4 bar speed density4 inch speed density intake with k&n filter
Aem uego
Aem uego
And most of the failures attributed to those turbos were due to improper oiling just like the FP series turbos before they mandated oil feed from the oil feed housing as well as a restrictor inline.
Revs to 7500 because of stock valve springs. I did find that the wastegate preload backed off which explained the decreased spool up all of a sudden. Will take another log here momentarily. I also am going back down to 25psi to see if that stock springs handle that better.
Furthermore on the ef4, I plan on going fp's stainless housing with external wastegate once all other necessities get completed.
Trust me it will end up like this. The cast rating on a cold side should be around a 4 or 5 is what mitsu uses, they used a 2 according to my turbo rebuild guy. I was making 30 plus lbs of boost when this happened decided to get a new wheel make it a little smaller. Well long story sort this is what we found. Now I have the same chra, Evo 9 hotside being mine was cracked, and a 25g cover. Long story short I still don't make the power I want and its coming off.
Per original post kelford 272 with stock springs. After talking to gsc and kiggly as well as kelford in likely being severely held back by the springs given my boost/cam/valce spring setup currently. I am going to drop the boost to 25 psi or so until I can get springs installed. In the mean time it gives me time to tune my 3 port I just installed today.
