2.4LR Evo 9 93oct Virtual Dyno Results
Old Mar 5, 2018, 02:29 AM
evo8vz's Avatar
My 2.3 on a Green hits peak tq at under 4000 RPM and full spool at 3800 RPM.
I am making 390 whp but 450 tq....and power falls off at 6000 RPM.
A 2.4 should spool even quicker and a 20G on an oem hotside even more so.
Old Mar 10, 2018, 02:33 AM
400s's Avatar
Did you do your pre-checks before getting someone to tune your evo?
Boost leaks etc?
Old Mar 10, 2018, 07:46 AM
CurseDSM's Avatar
Originally Posted by ConEvo
Update.
This weekend I tried to adjust the wastegate preload. the preload was far too stiff. Maybe 6 full turns. I adjusted it to 3 full turns and took it for a road test. It seems that it had slightly better spool but nowhere near from what is supposed to spool. Probably the hotside must have cracks. Here's the new log
Regards
Having to much preload on your wastegate isn't a bad thing, it would actually help the spool. You have other problems going on. I have that spool on a turbo the size of a black on my 2.4 so you have a leak somewhere.
Old Mar 10, 2018, 01:15 PM
ConEvo's Avatar
Another probable cause which is likely to be the problem. When I decided to replace the wastegate, I ordered a Forge IWG for evo 9, as i own an EVO 9 MR. When I tried to install it, i noticed that it was not a direct fit to the hotside door. I googled the turbo part number, just to find out that it was a turbo from EVO8 MR. I do not know if it has anything to do with this, but probably the door stays open. Forge, Turbosmart and other companies that offer actuators, they offer actuators for evo4-8, and different for evo 9. Anyhow, the turbo, manifold and also the wastegate will be replaced soon but I before I switch turbos I want to find where this boost delay comes from
Old Mar 14, 2018, 06:01 AM
ExViTermini's Avatar
The wastegate difference is due to the bigger compressor housing on the evo9 turbo's. Hotsides are identical in external sizing and wgate arm placement.
Have you checked mechanical cam timing?
Old Mar 14, 2018, 06:41 AM
ConEvo's Avatar
Not yet
Old May 23, 2018, 06:31 AM
ConEvo's Avatar
Sooo how are guys doin? As I am patiently waiting for my parts to arrive, I decided to share some pictures of my build
4G64 Block. It was actually in a very good condition. I even avoided to bore it, which was preferred for obvious reasons (Thin cylinder walls, HG issues etc)
Manley Billet 100m Crank
Carrillo H-Beam 156mm Rods. Surprised by the quality
Wiseco 1400HD pistons
Stock Rod-Piston
Carrillo Rod-Wiseco Piston. 135gr lighter than stock!!!
GSC Beehive Spring & Retainer Kit
GSC Race Balance Shaft
GSC Race Balance Shaft Weight. 751gr lighter than Oem
OEM Balance Shaft
Fluidampr Crank Pulley. Actually 1393gr heavier than oem, but totally worth it for its job
OEM Crank Pulley
ARP Crank Pulley Bolt
GSC R2 Cams
GSC R2 Cams
Supertech Sodium Filled Exhaust Valves (OEM size)
Supertech Black Nitride Intake Valves (OEM size)
Supertech Valve Seals
GSC Spring Seats
ARP Cam Pulley Bolts
ID 1050x Injectors
AMS Fuel Rail
ACL Crank and Rod Bearings. Also and Thrust Bearings were included in the build
ARP Main Studs
ARP Cam Tower Bolts
ORC Twin Clutch
ORC Twin Clutch
Engine Down
Minor Intake and Exhaust Porting
Kansai 4.11 Final Drive
Old May 23, 2018, 07:15 AM
ConEvo's Avatar
More parts that are in the waiting list. For now I am waiting for radiator and the turbo
Magnus V5 intake Manifold
T4 Divided Manifold
T4 Divided Manifold
Twin Tial MV-S 38mm Wastegates & S90 74mm Throttle Body
Kiggly HLA Regulator. A high quality piece!
Link Boost Control Solenoid
Walbro 450 Fuel Pump
Vibrant Oil Catch Can
Denso 1 Step Colder Plugs
Zaklee Clear Cam Cover
Prosport Carbon Hood Dampers
Old May 23, 2018, 07:23 AM
MR ArcticC's Avatar
Cool, it's going to be a nice build. What brand is that T4 twin scroll manifold? What turbo are you going to run?
Old May 23, 2018, 08:04 AM
ConEvo's Avatar
The manifold is a custom made from Exelixis Motorsports. The turbo that I am waiting is a Precision 6466
Old May 23, 2018, 02:13 PM
ctfpevoVIII's Avatar
Good luck with your build , you have a bunch of nice stuff going into it!
Old May 23, 2018, 02:28 PM
Suprised that you are going that all out and big turbo, but h beams
Old May 23, 2018, 03:24 PM
2006EvoIXer's Avatar
I think the Carrillo Pro H is a good choice for the 100mm crank. It will reduce rotational energy to reduce chance of crank fracturing at #4 oil port. I'm not a fan of LR because I like the pistpn rings spread out as far as possible to reduce cylinder wall wear.
Old May 23, 2018, 03:48 PM
The r&r i beams weigh like an h beam. Great choice for this application.
2006EvoIXer (May 23, 2018)
Old May 24, 2018, 01:52 AM
CurseDSM's Avatar
You got a lot of nice stuff on this build congrats. But I think you made one mistake. I can understand wall thickness of the block, but how do you know the cylinders are true? Hate to see you spend all that cash and have oblong cylinders in the block, specially when it came to a used 64 block. I was kind of surprised you went H beam rods as others did, but I know Carrillo makes nice stuff and those should be fine. Only other thing I can say is wasted money on those race balance shafts personally, and I think you should have went with a larger runner intake mani to help the air get into the engine given the larger displacement. Other then that thing should be a monster nice job. Looking forward to some #s.
Quick Reply: 2.4LR Evo 9 93oct Virtual Dyno Results
