Bought a used shortblock - let’s see what it’ll do...
#46
If you're looking at the 4.11 final drive then I would recommend getting a small brake kit and running a 24.5" slick on a 15" rims. Tire will work better with the gear that the 4.11 final drive produces and will be even easier on drivetrain than the 26" qtps are. Personally with you being a standard 2.0 though I would just leave the stock final drive and do an ultimate ratio trans. The 4.11 final drive in my opinion is better suited for stroker motors than 2.0s.
#48
Originally Posted by 2006EvoIXer
What's the strength of 1st gear with 4.1:1 FD? Will it survive long with 600wtq launches?
#49
Is2scooby (Oct 24, 2018)
#50
16* sounds about right for 8000rpm 38 psi. With flat top pistons it could be a little aggressive. I’m assuming your running E85 correct?
#54
After my track day a couple weekends ago, I noticed a tick coming from the head. Hoping it’s just a lifter that went bad. So ordered a few things since Black Friday specials are going on and will probably have to check the head out anyways.
GSC S3 Billet Cams
Skunk 2 Intake manifold
s90 Billet 70mm throttle body
gsc zero tick lifters
new valve seals gsc heavy duty
going to send the head to Buschur along with the intake manifold and have them hand port them. Then we’re going to make some jam.
Last track day for those curious.
Car went 10.16 @ 149.4 mph
#55
GSC S3 Billet Cams
#56
Should have done a Magnus V5 instead of the skunk.
And for head porting, Buschur doesn't really do a whole lot. If you haven't sent it out yet, consider changing direction there and getting a race port from head games.
#59
