Curt Brown 2.15L / GTX3582r GenI / EVO IX / Pump Gas
Engine built by Curt Brown
4g63 Block
94mm Eagle Crank (2037005900B7)
JE Asymmetrical Forged Pistons (297479)
Eagle Extreme Connecting Rods (CRS5900MBXD)
CB Ported Head
Kiggly Springs
R2 cams
CB Extreme Port Intake manifold with FB 70mm TB
Fuel
Squash Double Pumper (dual 485s)
PTE 1000cc (99.7% Duty Cycle )
Turbo/Exhaust
DIY short runner twin scroll manifold with dual 38mm Tial
GTX3582r Gen I
ATP 1.06 a/r T4 TS turbine housing
TurboSmart Oil Pressure limiter
3" downpipe to 3.5" exhaust
3.5" 100cell high flow CAT
3.5" Varex Muffler (valve open)
Thanks to Curt for the killer engine and I think this was his first shortblock with the Eagle 94mm crank.
Thanks to Aaron @ English Racing for the base tune and the 40+ emails he answered!
Thanks to mrfred for his help and explanation settting up the definitions for ECUFlash and EVOSCAN!
You can reference my build at the links below...
https://www.evolutionm.net/forums/ev...oll-setup.html
https://www.evolutionm.net/forums/ev...xperiment.html
I was able to make two runs and decided not to make a third run because IDC was hitting 99.7% and the car was running a hair lean. I typically see ~96% IDC on the street and I know I need to get a set of FIC1650's. Runs were done on straight Shell 93 octane, which is what I run on the street.
Here are the results of the second pass on the dyno and runs are done in 3rd gear.
Here is the log from the dyno run above
Here are both runs with Smoothing of Zero
I'm sure I missed some details so if you have any questions please ask.
4g63 Block
CB Ported Head
Kiggly Springs
R2 cams
Fuel
Turbo/Exhaust
GTX3582r Gen I
The following 5 users liked this post by 240Z TwinTurbo:
CBRE (Feb 26, 2019),
deylag (Feb 26, 2019),
hokiruu (Dec 26, 2019),
JohnBradley (Mar 7, 2019),
MR ArcticC (Feb 26, 2019)
Very nice results indeed. Is there a bottleneck on the fuel system? 100% duty cycle seems a bit high for the given horsepower. Do you have a larger feed line? I think typically 1000cc with double 450's and -8an feed line (including fuel rail) max around 650whp on pump gas. Prob pte injectors have around 5% losses in contrast with ID1050x, which given consideration with your dyno would be maxxed around 583whp.
https://fuelinjectorclinic.com/hp-calculator
So they are pretty much maxxed up, regardless the fuel pump, lines or rail. Having a look in injector Dynamics 1050x Dynamic Flow Data at 75psi(43.5 psi base fuel pressure + 30psi of boost) they flow 1390cc. If you add 1390cc on 100% duty cycle, they have 751whp on gasoline.
Very nice results, 400wtq at 4200rpm is impressive on pump gas.
This has me strongly considering a twinscroll Gen2 3582 for my car this year. I already contacted JMFab regarding their manifold and hot parts.
Anyway, just ordered some HighZ FIC 1650cc injectors.
That is not how it works for turbo applications. The 75psi flow data would assume a base pressure of 75psi and not the flow due to 45psi base pressure + 30psi boost. The fuel pressure regulator increases fuel pressure 1:1 with boost pressure to maintain a constant "differential pressure" of 43.5psi in my case. So with a base pressure of 43.5psi and 30psi boost you have 73.5psi of fuel pressure that is spraying into a 30psi intake so your injector flow is based on (73.5psi fuel pressure - 30psi boost) 43.5psi.
4g63 Block
CB Ported Head
Kiggly Springs
R2 cams
Fuel
Turbo/Exhaust
GTX3582r Gen I
4g63 Block
CB Ported Head
Kiggly Springs
R2 cams
Fuel
Turbo/Exhaust
GTX3582r Gen I
On the screenshot of your log there is the bottom line... Is that showing us your timing?
BTW, you can set your base fuel pressure to 75psi as you stated and the 1000cc injectors will flow like they are 1390cc injectors. However, if you run 30psi of boost you now have a fuel pressure of 105psi so looking at the Walbro 485 pump chart you have cut your fuel pump flow by ~50% vs 73.5psi fuel pressure (43.5psi base pressure + 30psi boost).
Construct (Feb 28, 2019)
What a powerband!!! I have been watching your builds and i like your approach! Trying to build cars with plenty of power but great response and minimal lag.
Im also running a GTX3582r and curt brown built head but on a single scroll T3 and higher compression 2.0L motor. Now that i saw this im thinking i should have built a high rev
stroker like yours with compression in the low 9's..... well food for thought for the next set-up!! Enjoy it man
