Buschur built 2.0LR with 6266 Gen 2
Just got my car back yesterday from AG Autosports in Ft Lauderdale, FL. (Highly recommend them)
made 707awhp on E85 and 567 on 93. Fully flex fuel.
They said my toxic fab manifold and dual 255’s are holding be back a little bit but I rather have it a bit conservative for longevity/safety.
Buschur spec 2.0 LR
Basically stock cyl head with stock size Ferrea valves, GSC S3 cams and springs.
6266 gen 2 ball bearing turbo
2150cc injectors, fuel lab regulator and Buschur double pumper
Exedy Triple Disc
TRE 12 plate rear diff
AG Spec Tcase upgrade
Halltech Elite 2000 Ecu
Crispeed Tuned
The pumps are fine as long as they're in good shape. If you still have a stock fuel rail, the AEM stock replacement is a good upgrade as it has more volume, as well as the STM kit to run a 6an feed line from the factory hard line that ends in the engine bay, up to the fuel rail.
The stock head and intake manifold is what's really holding it back though. It would probably pick up 40-50whp with just a Magnus V5 and 74mm TB.
Good results regardless.
37psi
