TTP BUILT 550HP RED+METH Evo IX
I just wanted to take the time to say thanks again to everyone at TTP Engineering:thumbup:. Scott, for all the advice and for and awesome tune {thumbup} Luis, for all the hard work and attention to detail you put into putting my motor together. Shane, for helping setting up the dyno and Ryan, even though you are no longer at the shop thanks for all the hard work you also put into my build.:beer:
Here are the mods TTP CUSTOM TUNE (stock ecu) TTP METHANOL INJECTION KIT TTP 880CC INJECTORS FORCED PERFORMANCE RED TURBO JE PISTONS 9:1 MANLEY I-BEAM RODS EAGLE CRANKSHAFT SUPERTECH VALVE SPRINGS SUPERTECH RETAINERS JAM VALVE LIFTERS KELFORD CAMS FIDANZA CAM GEAR AMS BALANCE SHAFT ELIMINATOR ACL RACE BEARINGS PPI EXTREME PORT MANIFOLD MEGAN RACING CAT-BACK MEGAN RACING DOWN PIPE MEGAN RACING TEST PIPE MEGAN RACING o2 HOUSING AMS COPY FMIC HALLMAN MBC(35PSI) INJEN INTAKE INJEN UPPER/LOWER IC PIPES GREDDY TYPE RS BOV ACT/TTP HDSS CLUTCH ACT STREETLITE FLYWHEEL SS BRAIDED CLUTCH LINES ZEITRONIX WIDEBAND/BOOST/EGT/ZAVT/FAILSAFE ARP HEAD STUDS WALBRO 255LPH FUEL PUMP The car on pump 93 was able to push 426hp and 351tq at only 23lbs I drove the car for the 1st 1500 miles after the build on pump and a cracked Megan manifold. The car was still very strong and it pulled nicely all the way to 7k. I was happy with it. I was able to get ahold of Wayne from PPI to do the Extreme Port Job on my stock manifold and it turned out great. knowing that I had the Meth Kit installed already just gave me the itch to see what it would do with the Meth on. The car made 550hp and 537tq by the time Scott was done with it. My goal was to be in the 530 range so you know I was really pleased with the final numbers. The car is really fast now. As a DD I think this power level is perfect Below are the graphs http://i188.photobucket.com/albums/z...g?t=1239076913 http://i188.photobucket.com/albums/z...g?t=1239076968 This is the difference between the Pump tune and the Meth Tune. http://i188.photobucket.com/albums/z...g?t=1239077005 Here is the Video http://i188.photobucket.com/albums/z...h_MOV00975.jpg |
Nice job man. Any plans on hitting the track with your new horsepower?
great #
Any trans work done? What PSI on old and new setup?
Can't wait to see what it does at the track! ! ! |
Great Numbers Take this beast to the Track!!!
thats bassically exactly what i am gonna do. i hope i get those good of numbers!!!! im just waiting on my red.
thats on stock ecu?
Originally Posted by playafly
(Post 6907325)
Originally Posted by NEVERBROKE
(Post 6907385)
great #
Originally Posted by nochance
(Post 6907417)
Originally Posted by slamsdime
(Post 6907468)
Originally Posted by merv414
(Post 6907484)
thats on stock ecu?
Very, very nice build brother and a great selection of parts. I have the Injen pipe set up myself but I'm considering changing out to the ETS LICP as it is wider in order to squeeze out a few more ponies.
Nice numbers!
Originally Posted by Evo2wIsh4
(Post 6908006)
I am thinking about taking it tomorrow to see what it does :)
Thank you, I am really happy with the new numbers. |
Nice build, great results.
What was the weather like to give you a +16whp correction? What compression ratio are these pistons ? |
Congrats Felix. Time to break into the 130's and mid 10's {thumbup}
Wow bro. this is what at&t pay checks do for evos felix? unfortunately for me nothing close to ur build ahha. congrats bro.
Originally Posted by evo8fl
(Post 6908114)
congrats Felix {thumbup} that is a beast, tomorrow should be a good nite is going to be cold like 40ish
Originally Posted by recompile
(Post 6908163)
Originally Posted by RyuEvoIX
(Post 6908394)
Originally Posted by evoixbri
(Post 6908425)
