Mikey's E85 FP Red 29-30psi 535hp/438tq
1 Attachment(s)
Here is my most recent graph of me converting over to E85. The graph shows boost at 31.40psi however English Racing's 5 Bar is drifting. The logs, which is posted below in the Thread only goes up to 30.1psi for one cell. Looks like max boost was roughly between 29.5psi. I'm very happy with the results so far, given the fact that I'm still on the stock 4G63, stock unported 84mm FP Red, and my small HKS cams.{thumbup} The rest of my mods are in my sig. Looks like we still have a lot left in the turbo for the power we are currently making. I will be adding a few more mods over the next few weeks before we upgrade to a 10:1 2.4L 156mm long rod motor with a FP Black;)
Attachment 338909 I love the way the car pulls:D Aaron put v7 on my car with the dual map tps switching. I have a 92map and a E85 map. I don't have a 92 dyno because we were pushed for time so we focused on my E85 tune. Over the next couple weeks I'll be working on a few modifications to the car and will be back at the dyno. Once again I would like to thank the ER crew for all their hard work! Lucas and Aaron we need to start my motor build;) ER is an amazing shop and some great friends of mine. If anyone wants a perfect tune and max performance, ER is the shop you want to visit. Mikey |
just got back from the dyno, it'll be tomorrow :)
I need to talk to you tomorrow as well, I'll call or text. I need food and a shower right now :lol: |
That's fine Aaron, when ever you get a chance. I would like to see the logs:D I won't be able to talk till 1400 tomorrow fyi. I'll be traveling...
Mikey |
Wow, you guys have been busy! Has Mikey's car been converted over to speed density?:mitsu:
Congrats Mikey! Have they finished the E85 pump on base up there yet? If not, you going to drive to Arlington every 3 days to fill up, or you just gonna run 92?
Originally Posted by sparky
(Post 8007026)
^ They finished the E85 pump on base about a month ago.
I hope everything is going well with you in FL. Miss you and cort. |
I got a question how big of a difference does the 80mm cover make over the 64mm i'm in the process of buying one now. Also very nice numbers by the way have you thought about going with more aggresive cams?
Originally Posted by VIIIrs
(Post 8007115)
Yes I will be upgrading my cams! I hate the HKS cams because they are so mild. I will be doing an engine build soon so I'm going to wait and put in a set of S2Rs then. Mikey |
Good I am glad you guys have E-85 available up there now! I just put a comment card into the NEX about getting E-85 on base here in Jax... let me hold my breath... Court and I are doing good, been really busy at work as of late ( in the middle of AMI) after that is over hopefully things calm down a bit.
Originally Posted by BLKCarbonEVO
(Post 8007146)
I honestly don't think the 80mm cover is worth any hp... However, the 80mm cover will eliminate surge. I had really bad surge with the 64mm cover if I ever did a 3rd or 4th gear pull. {thumbdwn}
Freddie, Good luck on trying to get E85! I hope they do it out there... Has cort found a job there yet?
VIIIrs, You will love your 80mm Red. It no **** sounds like a jet! The turbo screams{thumbup} Mikey |
ahhhhhhhhh dude i can't freakin wait thanks man!!!!! ahahha
Wow . Love that power curve. The torque stays nice and flat . Nice job
Nice power bro!!!! On Alk/pump you were ~520 correct?
Real nice power on moderate boost! Aaron is da man. You must be excited to have corn power now :D Just imagine if the Reds boost didnt drop off like it does.
| All times are GMT -7. The time now is 11:39 PM. |
