FP Red/4WS/ecu controlled Boost
Today I finished my tune with Tamer of 4WSTuning. I could not be happier. I can NOT get over how smooth the car is now. It is more powerful, and smooth as ice. Before I was road tuned twice by a reputable tuner.
This is where I stop and give the disclaimer. If you want to know who it was, its pretty easy to look at my past posts. I have nothing else to say about it. I wasnt happy, so I left that is all. Tamer Blows him away. As see in my mod list, I am running 1000cc PTE injectors. Before Tamer worked his majic, they were scaled to 622 meaning as if they were 700 series injectors. Tamer got them dialed in correctly and the way they idle and cruise is INSANE. When I was tuned by the last tuner, him and I both said that my car should be at 450 'no problem'. On my first tune I hit 430/386 on the same mods as now minus ECU controlled Boost(Forge Unos MBC). I had a flutter, and needed a new T/C plus a test pipe. I was told, come back and we will get the power. Needless to say I came back and made the same power with a different BOV and a testpipe instead of HFC. With the drivabilty problems, i just figured that I had to deal with a modified car. The car was running rich, injectors scaled wrong, and my boost was going way too high. (The reason I switched to ECU-controlled boost) I am now making more SMOOTHER power, at less boost than previously. Mod List: Fp red(64mm) ported ext manifold ported im and tb Cossie M2's supertech valve springs and retainers PTE 1000CC injectors BR intake BR u/l ic pipes W/ Race fmic BR TBE w/ bullet and TP O2 housing BR catch can Grimmspeed bcs Omni power 3 bar Single Walboro APS twin vent Shep transfer case Bushwacker tranny w/ HD twin Stock ecu http://i798.photobucket.com/albums/y...athankey16.png |
Do you have a graph starting from a lower RPM? This is pretty late spool for a red. Nice power though.
Also, what VDR mode are you in? |
I'll see if Tamer has one. This chart was the last pull and I started at 3800
on the other tune I was at 430hp-393tq |
The Mode is dynojet on vdr. We had to start the logs a little later to avoid bov flutter.
27psi tune Cheers! |
Great #s. Great tuner.
Glad you had a good experience with Tamer. Hes the man. |
Nice #'s and Tamer is the man.
flutter?...is it surging from the 64mm compressor housing?
good numbers. |
Amazing work as usual Tamer {thumbup}
awesome stuff man
Originally Posted by norcalSRTrida
(Post 8092339)
good numbers. thanks everyone for the kind words! |
good stuff man! i really look forward to doing business with Tamer. :thumbup:
tamer is teh man!@#
Originally Posted by EvolvedGTI
(Post 8092373)
Yes, I think so.
thanks everyone for the kind words! Mikey |
Very good!The FP spool up quickly.Do you have a graph starting from a lower RPM?From 3000 rpm maybe?
Good numbers on less boost! Looks like you made a touch over 450 however and not 461. See how it starts to trail down at 6800 rpm and then shoots back up? Thats because its not set right on the VDR. Also since you mentioned your last tuner (almost to let people know to check) he uses DLL software which reads a little lower than VDR. Why the old tuner chose to run 1000cc inj at such a low scaling is puzzling and why he chose to run 30 psi is disturbing, especially when you just made more at 3 psi less. Nice smooth power from 4WS
