91 Octane BBK Full and Kelford 272's
So I just rolled past 60,000 miles and that meant time for a timing belt change, and since that was happening, I decided to drop in some cams. Previous dyno was 313 awhp and something like 287 wtq with everything below except cams.
Evo IX BBK full ported turbo ported exhaust manifold speed element eleventy billion open air filter in hacked airbox Titek V2 O2 housing Deatchworks 880cc injectors Kelford 272 cams stock cam gears AMS downpipe and catback with highflow cat. JDM map sensor GM 3 port BCS Stock wastegate Stock recirc valve ETS Lower intercooler pipe mil.spec throttle body shaft seals Walboro 255lp fuel pump 25psi Tuned on 91oct by Sean @ FFTEC 354 AWHP and 331 WTQ http://img819.imageshack.us/img819/381/scn0003.jpg |
Nice power band! Great results!
nice, r u still using stock valve springs?
Hmmm,shouldn't your torque be a little higher then that? Maybe its just me,my IX put down 372awhp and 376awtq on a stock turbo with the same cams on pump on 27psi. Not dissing your numbers or setup,just thought maybe it was a little off.
Originally Posted by FraziersEVO
(Post 8973589)
Nice numbers! Cb |
Nice numbers on a mustang dyno
OP is using 91 octane. What octane and dyno did you use?
(Post 8973589)
nice #'s on fftec's heartbreaker!
(Post 8973589)
Originally Posted by CBRD
(Post 8973624)
On a mustang Dyno??
Nice numbers! Cb
Originally Posted by EvoVIII03
(Post 8973636)
Originally Posted by evogirl916
(Post 8973706)
(Post 8973624)
On a mustang Dyno??
Nice numbers! Cb My car was tuned on AWD Motorsports DynoJet,93 pump gas is what I use unfortunately,lol. |
nice 91oct power.. frazier you wont get that torque on a mustang.
Originally Posted by tscompusa
(Post 8975179)
| All times are GMT -7. The time now is 06:10 AM. |
