MAP 2.4L + FP Green HTA + 93oct
Below are the unfinished results of a quick tune on 93octane with the following mods. We did not get to finish the results on 93oct, but these show the potential of the evo when the proper parts are combined and work well together. My two customers choose to work together and now this car is going to get an FP black instead of the FP green, so ill never get to finish the Green tune on this car, however the black should make for some nice numbers once complete.
The following chart shows the cars power in different boost levels. You will notice even at the lowest boost setting the car made more power uptop then the other higher boost settings.. this is because one extra degree of timing was used during that run.. the car most certainly had a little more in it yet, but we didn't get a chance to push it because I was tuning him as he was traveling across states and the weather changing was effecting our tuning due to him climbing very high altitudes so we decided to stop. Fuel: 93oct Evo: 2003 evo 8 gsr Important Mods: Map 2.4L Map stage 5 head FP Green HTA Map rev 3 intake manifold Fic 2150cc BR double pumper GM 3" maf and maf translator Sparktech non cdi ETS 4" FMIC Turbosmart Race Port VTA BOV GSC S3 custom cams AEM TruBoost Quick tuning notes: 12* max uptop & 2-3* at peak boost. In detail the boost during runs were as follows: Green Line: 21.78 psi spike tapper to 19.17 Blue Line: 24.38 psi spike tapper to 19.88 Red Line: 26.99 psi spike tapper to 20.36 All in all I believe this car would have passed the 500whp barrier on 93octane if given more time to tune the car. http://oi56.tinypic.com/2r2ocrd.jpg |
Wow! nice job on pump gas! congrats tom!
Torque on her is rediculous with such fast spool and response. If you're not already sitting all the way back it will throw you. Amazing job Tom... now for the FP Black.
pretty much exactly what I put down with my new set up on pump gas...
Nice power
My next turbo... |
Originally Posted by Fast_Freddie
(Post 9182368)
150mm or 156mm rod?
Very good #'s |
I have almost the same setup with a MAP 2.3L motor/HTA green 94 octane and results are very close.. I broke 500hp with "virtual dyno"..
The only difference is.. my air/fuel ratio are at 11.8 taper to 11.5.. My max boost is at 26-27psi and taper to 24psi.. almost same timing.. I have couple questions... no matter what I do with the timing/fuel.. I still get 1-2 knock at approx 3800-4200rpm.. Do you have the same issue?? Why do you taper the boost so much to 19-20psi?? it doesn't help your HP if you run more boost? I will try and find my dyno sheet and post it up.. Thanks. Philip |
That is a ****ing beautiful powerband man! Congrats!
Nice! Threads like this make me happy and can't wait until my build is done!
cant wait to finish assembling my 2.3 HTA green. hoping for similar results.
How's the idle with the S3s?
Originally Posted by pizzamanevo8
(Post 9182348)
(Post 9182368)
Originally Posted by keath
(Post 9182488)
Nice power
My next turbo...
Originally Posted by BigT
(Post 9182672)
Thanks for sharing! I thought this thread was about a MAP tuned car?
Originally Posted by S13 Curtis
(Post 9182972)
150mm or 156mm rod?
Very good #'s
Originally Posted by sw20
(Post 9183062)
The only difference is.. my air/fuel ratio are at 11.8 taper to 11.5.. My max boost is at 26-27psi and taper to 24psi.. almost same timing.. I have couple questions... no matter what I do with the timing/fuel.. I still get 1-2 knock at approx 3800-4200rpm.. Do you have the same issue?? Why do you taper the boost so much to 19-20psi?? it doesn't help your HP if you run more boost? I will try and find my dyno sheet and post it up.. Thanks. Philip Yes that is where I would of liked this car to be also.. 11.5-11.8 afr and it would have went past the 500 barrier with just afr.. it also had some more timing in it with less boost. it probably would have passed well over 500 at just 21psi minus the fun torque. Why did it drop boost so much? I do not know.. I don't know if its due to the 2.4 airflow charactoristics or the tru boost just not good in general. Personally i would have put ecu boost on the car if i was keeping the setup and force the boost uptop as much as possible. When we were tuning spool for this car he was hitting it around 2200rpm and it was fully spooled by 3200rpm. Pretty impressive considering it has Huge cams.
Originally Posted by Jrah2987
(Post 9183240)
http://www.youtube.com/watch?v=6t2EZlmcdss |
good power!
(Post 9182972)
150mm or 156mm rod?
Very good #'s |
