'05 Evo8, GSC S2 cams (317whp/322wtq)
1 Attachment(s)
Customer: Andrew R.
Vehicle: 2005 Evo 8 Grimmspeed Boost Solenoid @25psi (boost control per gear) Tuned By: Jamie@Dynotech Tuning (jack_of_trades)GSC S2 Cams Beehive Valve Springs (stock retainers and keepers) Stock Cam Gears Stock Evo 8 turbo with 10.5 hotside Stock intake piping with cone filter adapter Stock LICP (ouch) Stock UICP Stock FMIC Megan O2 Housing 3" Tueboback Exhaust with Test Pipe ACT 2600lb HD clutch Evo 9 MR BOV (slightly crushed) Bosch High Impedance 900cc Injectors 255lph Fuel Pump The items in BOLD can be upgraded for more power potential at a later date. Results: 317WHP/322WTQ (3rd gear pull) The base pull was a street tune by another shop prior to us installing the cams. I was quite impressed with the power improvements of the S2's on a stock turbo with so many stock parts still in the mix. Enjoy it AJ! https://www.evolutionm.net/forums/at...1&d=1302567944 http://highboostforum.com/forum/atta...0&d=1302564344 http://highboostforum.com/forum/atta...9&d=1302564343 |
Damn impressive for stock IC and DP...
Originally Posted by Fast_Freddie
(Post 9233226)
-Jamie (jack_of_trades) |
I was incredibly impressed and extremely happy with how everything turned out. The numbers alone show what great work is done at Dynotech tuning. They will definitely be seeing more of my business in the near future :)
Sorry Jaime...yes stock piping...
Nice! Another example of S2's not losing anything down low - I think that's pretty cool :thumbup:
Congrats on veru impressive results! Now I canīt wait to install the S2īs myself, was boost the same on the base pull and final tune?
Cheers, Ricardo |
Originally Posted by RJSP
(Post 9234841)
Cheers, Ricardo -Jamie (jack_of_trades) |
Hi Jamie, congratulations again on the impressive results, and at only 1 - 2 psi more! Can you share about how much the fuel leaned out/had to be compensated in general to keep the AFR at safe level?
Iīll be doing this mod shortly and would greatly appreciate your input on how the S2īs affected the original fueling. Thanks, Ricardo |
(Post 9235561)
Iīll be doing this mod shortly and would greatly appreciate your input on how the S2īs affected the original fueling. Thanks, Ricardo -Jamie (jack_of_trades) |
Thanks for the pointers {thumbup},
Ricardo |
i need to stop reading your threads since i live like 10 minutes from your shop now lol.
i cant be spending more money on my car! nice numbers, do you know what a basic bolt on 23ish psi car makes on your dyno? |
Great #'s on a Mustang! How do these cams compare to say some HKS 272's?
Originally Posted by killerpenguin21
(Post 9235878)
i cant be spending more money on my car! nice numbers, do you know what a basic bolt on 23ish psi car makes on your dyno? https://www.evolutionm.net/forums/ev...hp-279wtq.html Upgrade to a Grimmspeed 3-port boost solenoid and I could probably get even more power up top since his AEM Truboost EBC can't hold boost as well. -Jamie (jack_of_trades) |
Originally Posted by NorCalEvo415
(Post 9235923)
These are more aggressive than the old HKS272's and flow a little more. They are both great cams but I would say that the GSC S2's may give slightly better results. Plus, the S2's sound sooo much nicer! There is a sound clip here if you would like to see. EXHAUST SOUND CLIP HERE -Jamie (jack_of_trades) |
