Akeric's Evo IX MR, bolt-ons, meth, self-tuned, input?
1 Attachment(s)
Updated 7/12 with new VD,.....about all I can get out of it for hp, torque is kept lower for rods sake.
https://lh3.googleusercontent.com/-S...00/398dyno.png Updated 7/4 with new VD plots Mods are MAperformance LICP, BR o2 housing and downpipe, Road Race Engineering Cat-back, test-pipe, Amsoil filter, ETS intake, Grimspeed EBCS and Aquamist HFS-6 spraying 60/40 meth/water mixed by volume. Oh yeah, 90 octane fuel also. I know the afrs are a little unstable, I need to work on smoothing it out a bit. Hopefully I'll get a few more tweaking the timing further. https://lh3.googleusercontent.com/-9...dyno7-2-11.jpg Update VD plots Red and blue are most recent, I did make changes between yellow and green and red and blue runs. I think the inconsistency is from the ecu controlled boost. I am still under shooting a little bit. After tweaking the fuel and timing maps a bit more I managed to pick up some more ponies so I'm pretty happy. These runs were made with half a tank of fuel. https://lh3.googleusercontent.com/-h...s800/dyno2.PNG Also here is my non-meth map, its not highly tuned, I kept it conservative, personally I'm surprised it made as much power as it did. This run was made with fuel almost empty, even light was on. So thats probably worth a few horses. https://lh5.googleusercontent.com/-6...s800/dyno3.PNG |
Good number for being on 90 and no cams. congrats!
Also congrats on it being your own tune with meth! |
Looks pretty solid. You are on the right track. Just keep tweaking
Any chance in seeing a graph without meth? For comparisons sake?
Originally Posted by 211ratsbud
(Post 9436492)
Well I do though... I wanna see what the method is.accomplishing
I would run a few more logs through VDR. The torque hike up top looks a little weird.
Good number none the less. |
(Post 9436814)
Updated with new runs from tuning this evening, also now includes my non-meth map.... enjoy :)
good work nice for minimal mods
updated, newest map is on 80/20 meth/water and 26-27psi peak and then holding as long as possible, only other change is I crushed the stock ix bpv.
Gotta luv the meth kits eh ... old roomate has a turbo GST which has a GT35r on it and he runs meth on it ... 32psi and a dyno sheet of 530 ish
good work , great numbers
| All times are GMT -7. The time now is 09:45 AM. |
