Buschur Racing-HTA3586, HTA3082, HTA3076 comparison
In the never ending search I always seem to be on to find something better I ended up in some turbo testing this week.
My car for the basics runs: BR2.3 RPM engine BR Stage 3 head BF272 cams BR double pumper ID2000 cc injectors BR Race FMIC BR upper and lower i/c pipes BR Forward Facing V-band turbo kit Tial wastegate and Tial BOV E98 Fuel I have been enjoying the hell out of my car all year with this combination. By far the best combination I've ever had in the car. I've only had it on "low" boost so far, max being 35 psi and that was during this testing trying to set boost when I made changes. The car is a beast and still has enough low end to manage to autocross it and do fairly well, I'd actually say the alignment/tire choices I have used for autocross is a bigger handicap than the power delivery which is pretty darn good. OK, to the testing the three turbos used were: Forced Performance HTA3586 with a Tial .82 turbine housing Forced Performance HTA3082 with a Tial .63 turbine housing Forced Performance HTA3076 with a Tial .63 turbine housing Below is the dyno chart from the three turbos. I printed the sheet so each turbo has it's own color. Red=HTA3586, Green=HTA3082 and Blue=HTA3076 http://img.photobucket.com/albums/v2...URCOMP1020.jpg **I'd like to be able to do a nice spread sheet for all this, sorry, don't know how to do it. More facts. HTA3586, peak boost was 33.1 psi, at 8,000 rpm it had 32.7 psi. At 3,000/3.2 psi, 3,500/7.2 psi, 4,000/14.2 psi, 4500/28.3 psi, 5000/32.3 psi HTA3082, peak boost was 32.7 psi, at 8,000 rpm it had 28.9 psi. At 3,000/4.8 psi, 3,500/11.2 psi, 4,000/23.5 psi, 4500/32.2 psi, 5000/31.9 psi HTA3076, peak boost was 34.1 psi, at 8,000 rpm it had 27.3 psi. At 3,000/5.9 psi, 3,500/13.7 psi, 4,000/29.9 psi, 4500/33.1 psi, 5000/32.4 psi. More information of interest. This is RPM, then turbo, then TQ/HP 2500 rpm, HTA86, 115/57 2500 rpm, HTA82, 125/62 2500 rpm, HTA76, 125/62 3000 rpm, HTA86, 133/76 3000 rpm, HTA82, 144/82 3000 rpm, HTA76, 153/87 3500 rpm, HTA86, 181/120 3500 rpm, HTA82, 207/138 3500 rpm, HTA76, 233/155 4000 rpm, HTA86, 281/214 4000 rpm, HTA82, 342/260 4000 rpm, HTA76, 414/315 4500 rpm, HTA86, 456/390 4500 rpm, HTA82, 482/410 4500 rpm, HTA76, 520/440 5000 rpm, HTA86, 540/510 5000 rpm, HTA82, 516/486 5000 rpm, HTA76, 529/499 5500 rpm, HTA86, 546/567 5500 rpm, HTA82, 513/532 5500 rpm, HTA76, 522/542 8000 rpm, HTA86, 458/679 8000 rpm, HTA82, 389/579 8000 rpm, HTA76, 378/563 OK, those are the technical facts of the test. Some side notes. The boost was adjusted to get them equal. I went a little high and then a little low on the HTA3076, I figure for the test it was close enough. Each psi was giving me about 10 hp/ft lbs. So figure from there if you are unhappy with the 34 psi on the HTA3076. At 35 psi it made 577 peak. The AFR's were set at 12.0:1 across the board from 3000 rpm up for each one. I did have to pull a few degrees of timing through the mid range on the 3082/76, it didn't like the smaller turbine wheel with the timing I was running. We are doing one more test today by Robert's request. The car is having an .82 turbine housing put on the HTA3076 right now. He feels the spool will not be effected and the power is going to climb. In my opinion, based on what I am seeing the HTA3076 is a better match than the HTA3082, the low/mid range is great and the power up top is minimal that is being lost. Both turbos carry enough power all the way past 8,000 rpm that you could run the cars that high if need be and benefit. Shift points wouldn't need to be past about 7,000 rpm for the car to ET well but in 4th to cross the traps letting the engine rev would benefit it. |
This is one of those rare times that I'm not sure the smaller faster spooling turbo is worth it... the power under the curve with the HTA 3586 and huge increase in peak is just so good. It spools fast enough to be totally usable for anything other than maybe autox and the peak power is ludicrous even on low boost.
Also, for reference. This all started over the EFR thread posted elsewhere, the search was to find a turbo that could match the EFR. This HTA3076 is a bad little dude, it is running more boost than the EFR was, I think it was at just short of 30 psi. The spool up is also not quite as quick as the EFR. I think a better comparison will come when the EFR turbo gets put on a Dynojet and I think that is scheduled to happen tomorrow. I am going to request the EFR to be run at 33-34 psi to try and get the comparison as close as possible.
Interesting test! I'm looking forward to the results of the .82 housing on the 76. I love to see tests like these.
The HTA3586 is one bad dude and it's my favorite only from doing so many turbo tests over the years. This car has over 1,000 dyno runs on it.
The HTA3076 has a huge increase in low end power though. For someone looking for a responsive yet powerful T3 option I have to say that turbo is the ticket. I mean at 4,000 rpm the HTA3076 makes 133 additional ft lbs of torque and 101 whp over the HTA3586. For a car you drive and still want to run fast, that is substantial. This HTA3076 is actually going to find a home on my '32 Ford I built with the EVO engine in it. I have a super low mileage HTA3586 for sale;) |
Originally Posted by David Buschur
(Post 9684032)
The car with the EFR is R/Ternie's car? |
Thanks for posting the results. I wish FP would send you a 3582 while there at it haha
R/T doesn't have an EFR as far as I know and if he does the results are not posted. The results are on Leetevo's car which has the same engine/head in it as my car.
David,
If i remember correctly, didn't you auto X with your 3586? The 2.3 must have helped to spool quick enough to use the power, but the 3076 looks to be more suited for the application and 3586 for top speed pulls, drag for those who will high rev. Thanks for testing |
Im loving the 3076 Spool
Very nice comparison. The difference in spool judging by the chart would make me go with a 3586 any day, but the real test for me would be driving both setups around town to really see which one you like more.
I can vouch for the HTA3076 i won against a gtr on bracket racing!{thumbup}
Omg 3076 stroked love. Very nice.
Well I typed a long post and our internet did me in, I'm not typing it all again!
The .82 housing had very little effect on the spool up, Robert was right and about the same effect on top end. It seems the turbo didn't care much either way. I found the same thing with the HTA86. At 35.5 psi of boost the car made 576 whp and 547 ft lbs (off the top of my head, I am home now). I layed that graph over Curt Brown's FP Red graph, he holds the record on our dyno for an FP Red. His car had a peak boost of 36.2 psi. The HTA3076 is virtually identical with more power in the mid range. I'd highly recommend this HTA3076 for someone wanting to go with a responsive T3 set up that could be autocrossed and still run in the 9's in a well prepped EVO. It's going on my street rod for sure. |
Originally Posted by Broham
(Post 9684173)
David,
