My 2003 EVO8, on E85 Stock Turbo 400+whp
2003 VIII with sunroof
Mods: Stock Block Ported Head / IM / EM HKS 272 i/e with Supertech single valve springs RC 1200 cc injectors Single walboro FP Stock VIII Turbo with 10.5 hotside Stock wastegate / pre load adjusted TiTek 02 V1 TBE with test pipe APS CAI Weapon R upper/lower pipes Spearco FMIC Synapse mini bov Exedy twin HD ECU Controlled boost E85 @ 30 psi peak V7 ROM Self Tuned.. http://img35.imageshack.us/img35/3703/1211112.png |
3600 lbs. How many occupants did you have in the car with you?
unless he weighs 500 lbs all by himself lol
car has full tank of gas, some tools in the back, and a sunroof. I guess it to be 3400lbs plus me 200lbs.
fwiw my ssl with me in, with spare tire and a bag of tools was 3498 and I weigh 160.
that curve is smooth as ****! you tuned? Nice!
Originally Posted by mxguy1286
(Post 9815534)
Nice numbers. Weight seems a little high, but whats with the super lean AFR?
Originally Posted by BigT
(Post 9815753)
x2 super lean is right
Max torque at 5300? Something is up here...
Originally Posted by SRToad4
(Post 9815797)
get it weighted man, you're discrediting yourself big time by representing 3600lb on the forum and claiming the #'s. or rerun it with the extra weight out and use the regular weight.
either way the power is strong.. i recommend you also post your mod list in the opening thread.. it helps others learn what they can do to get to certain power levels. :) |
Originally Posted by tscompusa
(Post 9815915)
Yea i would like to see full mods list Please
