will this get me over the 500whp mark?
i recently sold my MR and im ready to start my second Evo project, (dont actually have a car yet) my MR had 405WHP, im looking to at least hit 500 with this one (dynojet)
so ill give u the quick run down with the important info all bolt ons (TBE, LICP, UICP, FMIC) ported exhaust manifold BBK Full ported turbo Kelford 272 cams, valcesprings, retainers injectors (not sure what size i should use for this setup, maybe 1250cc or 1400?) Fuel pump (not sure if a walbro 255 is enough, maybe i need a double pumper?) E85 tune so what do u guys think. will bolt ons, cams, BBK full, get me over 500whp on e85? thanks guys! |
Yes, be carefully your drivetrain at that powa.
1250cc injectors and a double pumper should get you there. Just watch the torque and you'll be good.
I think a DBB FP Red would be better for this setup. Either way, I'd build the bottom end to play it safe, instead of spending a ton on new parts and running the risk of destroying everything with a high torque setup. The BBK full will probably get there, but it'll be maxed out.
you'll have to wring out the bbk full, and still may not quite get you there. shouldn't have any prob hitting 480 whp though. if you want a solid 500 whp, think green or ef3. jb hta greens are still available - proven street turbo at a great price point. a single walbro alone wont get you there safely; a buschur doublr pumper or the new walbro 465 are better choices. also, oil control starts becoming a very important factor at 500 whp. a kiggly hla and buschur pan are good insurance.
Originally Posted by mrfred
(Post 10215271)
(Post 10215271)
He could run 2 walbro inline with a hobb switch. That would save you a couple hundred dollars.
(Post 10215271)
is a buschur double pumper a direct install like the walbro 255 is? |
Originally Posted by Nelson999
(Post 10216238)
^alright cool.
nobody called out the fact that i forgot to add headstuds to the mod list up there ;) |
(Post 10215271)
(Post 10216268)
so you think a HTA green or FP red would get me to 500 easier?
1200cc injectors and new walbro e85 pump
I could help you with a great deal on an Fp red journal bearing brand new still in box. I have one on my car now stock block making 462 whp on buschur Dyno on 93 oct.
