BR 2.3 - FP Black DBB - 36psi - E85
(How to read this thread - Starting from the top to the bottom - The top is all old content & the new is at the very bottom)
Worked all day on my car. Speed density is far superior to the maf.. ill never run a maf ever again. The car made a max of 570 (553 SAE) on its old setup @ 36psi at redline in 3rd (peak horsepower area) Shown with the graph below. Below that area the boost spiked as high as 43psi. http://www.tscomptuned.net/_images/documentary/psi1.jpg Now you can see the car is very different. There is no more spiking the boost to the moon anymore to hold boost. It is now using a 3 port and a mbc combined. (hybrid boost) Temps were 75F out and this was done on the interstate on a major route near my house. The smoothing used is the smoothing i feel best shows the vehicles true output power level. Here is what it made tonight: http://www.tscomptuned.net/_images/d.../personal1.jpg Due to traffic, I could not load the car up down low to show a better comparison under the curve, but that isn't even the area i care about anymore, but i know others do. Let me just say i cant notice any loss of power down low, if anything it feels more responsive. I had timing loaded in the car and had it aggressive, and it peaked around 570wtq.. but i took it back out. that's not what I'm after. what I'm after is 1/4 track powerband usage. Here is an overlay of the boost now and the boost ran on that dynojet for reference. http://www.tscomptuned.net/_images/d...ary/boost1.jpg If all goes well ill have time slips for the car by Wednesday. Here's how the new setup looks: http://www.tscomptuned.net/_images/d...ed/engine2.jpg Changes from the Dynojet Research Graph at the very top were the following: Map rev 3 intake manifold replaced by an AMS F1i intake manifold 65MM mil.spec throttlebody replaced by a 70mm Full Blown Map ported exhaust manifold replaced by a ToxicFab Tubular Manifold Muse upper pipe replaced by an ETS upper pipe for AMS f1i Forge RS BOV replaced by a Tial Q BOV FP intake + perrin foam filter + MAF replaced by JMFAB 4" intake pipe + 9" K&N cone filter (SD) All the above yielded about 40WHP gains at the same boost level at peak horsepower area. (over 70whp gains throughout the powerband) The only thing I have to do next is replace the Kelford 272 for GSC s3 which i will document the power changes and show the difference in MPH at the drag strip with the 2 sets of cams. Hopefully my information will help somebody else.. that is why im documenting it all. Important power mods: BR 2.3L BR stage 3 head Kelford 272 BR Race FMIC BR double pumper FIC 2150cc JMFAB 4" intake pipe + 9" cone filter Tephra v7 Speed density grimmspeed 3 port --> hallman mbc cobb 3" tbe Toxicfab tubular manifold Tial Q bov 70MM full blown AMS f1i intake manifold Invidia o2 housing FP Black DBB Ported Sparktech non cdi Those are the basics. Will update with timeslips. Any questions feel free to ask. update: took it to the track and it did a quicker time but the mph was not there yet. ran into some complications. read here for more information https://www.evolutionm.net/forums/10371516-post47.html heres some driveability videos of the SD Tune also: www.youtube.com/watch?v=3Z_ZseE-7C8 ------------------------------------------------------------- Track results & Kelford 272 vs S3 comparison: Final track results here with kelford 272: https://www.evolutionm.net/forums/10388469-post77.html Kelford 272 vs GSC S3 swap out comparison not 100% 1 on 1 accurate, but the car has picked up quite a bit of top end https://www.evolutionm.net/forums/10397480-post85.html - Final GSC S3 power pull results (195lb passenger onboard): http://tscomptuned.net/_images/dyno-...d-19thsept.jpg - these are the final results after getting the proper weight of the car and doing more pulls.. next update will be with time slips.. after i have a slip of s3 vs kelfords i will share then make my final decision on if the s3 are better then the kelfords.. track approval pending of course. https://www.evolutionm.net/forums/10452979-post118.html |
Nice numbers buddy!
Collin |
Looking good. That fuel line looks good too!
Looks good, Tom. Might have to give the hybrid boost a try so I can limit my tq spike and keep building power up top. 138 or bust.
Looking great Tom. I'm interested in doing SD also but not sure how hard it would be for me being my car doesn't come with a map sensor from factory.
i like!!
Very nice Tom. Car will definitely trap somewhere between 135-138.
Perfect engine bay. Impressive gains!
Interested in the comparison of the s3's. Will the displacement help the spool lag? or will there even be a difference? |
Originally Posted by prowakeskater
(Post 10363169)
I'd be curious to see a before/after on the same measurement tool. Can you do VD overlays of before/after?
This is not a challenge, I'm truly curious. |
speed density 2d or 3d?
wow those are some massive torque losses.
4000 its down 80 4500 its down 130 even 5000 its 70 before it looked fun from 4500-7700 now its looks fun from 6000-8000 two different beasts for sure. and no tellin which parts are helping or hurting with sooo many changes. so important to make one change at a time and assess. |
The boost is not spiking to 43psi anymore which is causing lower tq numbers. He doesn't want to have to spike the boost so high to hold power out the top. If he spikes 43psi again I am sure a good portion of the lost tq would reappear quickly.
When you can use a 3-port to tune boost for the entire rev range, why are you using an MBC as well? Your WGDC tables must look real weird.
Good to see youre happy with the new setup, be interesting to see what the S3's do. |
Originally Posted by batty200
(Post 10363380)
.Due to traffic, i could not load the car up downlow to show a better comparison under the curve, but that isnt even the area i care about anymore, but i know others do. let me just say i cant notice any loss of power downlow, if anything it feels more responsive. I had timing loaded in the car and had it aggressive, and it peaked around 570wtq.. but i took it back out. thats not what im after. what im after is 1/4 track powerband usage. |
