Stock evo 9 turbo in kill mode E85 Built 2L S3's
Just finished up tweaking Pete's car on E85. This car is a beast! Were looking for a 10 second pass on the stock turbo. The car previously ran 11.3 @ 120 with around 410whp vd.
Boost: 35psi Fuel: E85 EMS: tephra v7 speed density Loc: NY Mods: Evo 9 RS (2 passengers in the car) Built 2L 10.5:1 GSC S3's Ported stock IX turbo 18psi WGA Ported Ex mani by Curt Brown Shearer fab o2 dump BR v-band TBE BR Race FMIC BR UICP BR mini battery kit SynapseTurbo LICP Tial Q BOV Hallman MBC Walbro 255 modded PTE1200's Exedy triple http://www.tscomptuned.net/_images/d...9/pete/e85.jpg Results are not final, but good enough to share. The car is equipped with a 3 port as well, but i was afraid to use it, so we just left the table zero'ed out for now. I don't want to grenade the turbo. 35psi spike down low is pushing it as it is. |
Power everywhere, a solid 400whp+/400ft lbs+ mustang dyno. Looks like I need an o2 dump, curt brown ported exhaust mani and a tscomp tune ;)
Damn that thing looks like it would be a hoot to drive. Good job on the tune Tom.
that is sick power for a stock turbo, he needs to take it too the track!
Looken good Pete. I'll see you in ESA at the Shootout :)
Its an interesting AF curve. I guess I'm most shocked that Pete has that kind of down low grunt while running the S3s. Is that because of the engine compression, bleeding edge boost levels or both?
When I see a build like this I wonder why this selection of parts. Why not simply go with a 2.3L with a slightly bigger turbo then run lower boost? |
Nice power band. I'm looking to do a almost identical set up.
What are you waiting for, pull the trigger!
Originally Posted by scoopevo
(Post 10736328)
Tom based on your experience with the S3s on little turbos...Do you prefer the S3s over the S2s? What are your thoughts? Nice numbers btw.
Originally Posted by AWD96
(Post 10736122)
Originally Posted by Jeff_Jeske
(Post 10736158)
When I see a build like this I wonder why this selection of parts. Why not simply go with a 2.3L with a slightly bigger turbo then run lower boost? The 2.0L is just small enough displacement to not be to big for the stock turbo, therefore you can do things with the turbo that you cant on larger displacements, where the stock turbo would be not enough turbo for the larger engine. I feel this is one of many reasons the car took 35psi like a champ and just made a really great low end torque curve for a 2.0L engine. (don't forget mivec!) a 2.3L would spool the turbo up sooner, making even more low end due to the quicker spooling of the turbo, but it would not be able to run the same boost as the 2.0L can as safely. it is quite interesting when you look at it this way. in this perspective boost can sometimes make up for displacement. (although the displacement is always going to get there first though) I think once were done i can get the car to 470/470tq, but maybe not. normally you do not see more torque then hp in these cars unless the tune is conservative at higher RPM or something is not being done with the tune to not allow the HP uptop. not the case here. I am thinking once i add more boost uptop with the 3 port (right now its not being used,) we can potentially increase the HP to match the tq ideally. A Lot of his power #'s come from the mod list. the parts combination is just working really well.
Originally Posted by Rondata.
(Post 10736305)
Originally Posted by mean4g63
(Post 10736555)
on paper you would not want to go bigger then the S1's on the a stock turbo car because the S1's are designed for the low/mid range more then top end such as the S3. However we have done cam swap back to back testing and it has shown the S3's are worth the swap for the little low end loss. |
(Post 10736158)
Very nice! Liked to have a setup up like this. What's surprising to other people is that they're shocked to see this from a stock turbo.
This has me thinking. I have most of the mods he does. I'm thinking about adding s2, open dump, and 3port and gsc springs and retainers. I don't have e85 but I have meth. Just can't decide whether I should get the mods I described or just get a bbk full. It will be around the same price either way. Been wrestling with this for awhile now. Great results though!!! If I ever decide to do a remote tune I would go with Tom for sure. Always seems to squeeze great results out of every setup!
Nice cant wait to see what his car does now.
| All times are GMT -7. The time now is 02:50 PM. |
