BR 2.0L 6266 S3 93oct 26psi
Jack changed his setup a lot, so i recently retuned it. He took it to the track and said the trans / clutch combo was giving him trouble, but still managed a pretty good ET.
The dyno was done at night with colder air temps & denser air, about 40F colder than when he visited the track, so i suspect the vehicle will trap somewhere around 127 or so in the same temp conditions he was being tuned in with a cleaner pass. Loc: PA ECU: tephra v7 speed density Gas: 93 octane Mod list: BR stage 3 2.0L (manley crank / manley rods / je pistons) BR Double Pumper BR Race FMIC Precision Journal bearing 6266 GSC S3 Cams (Supertech Dual valve springs and ti retainers) CBRE 70mm Stock Ported Intake manifold Full blown 70mm throttle body Spoolinup COP Standard Arp head studs Tial QR BOV Tial 44mm mvr wastegate 4'' SD intake with green filter Precision 1000cc Injectors Greddy Tic Exhaust Hallman MBC Graph: http://www.tscomptuned.net/_images/d...ackR/JackR.jpg Slip: (40F warmer temps then dyno temps & more humid - estimated 500WHP at the track due to weather) http://o.aolcdn.com/hss/storage/fss/...cb1868426f1171 E85 is next. |
Car drives like stock.. Until you floor it and it puts 600cc bikes in their place! Tom dialed the tune in perfect on this one. It's truly a monster on just 93oct on e85 it's going to be crazy!
nice power and good pass but i would think should have made it in high 10's
Originally Posted by boost556
(Post 10755430)
even a 1.40 60ft wouldn't get it done, it would need to be colder out + perfect driving, which just doesn't normally happen for everybody. If i was him id be happy with a 11.3 on 93oct. The traps obviously down a few mph due to the not clean pass + hotter temps (540whp dynojet typically does 127-128). but all in all the car is pretty quick and is more than enough power to have fun with and enjoy on the street on 93. Now on E85 a 10 should be on his first pass unless he gets locked out or something doesn't cooperate. |
Originally Posted by Evo3573
(Post 10754955)
Originally Posted by tscompusa
(Post 10755834)
Thanks Jack for the kind words! Your car should be an easy 700whp+ on e85. the only thing we need to do is swap the injectors out for something like 1450cc fic. I haven't mentioned this to you yet, but i'm not going to charge you to set the new injectors up on 93. :)
Very nice. Would their be any benefit of replacing the mbc for 3 port with this setup?
Nice stuff!
Tom, could you share what peak timing you use at peak tq and in the high rpm range? |
Great results!
Originally Posted by Sil'vr-Boi6
(Post 10761198)
Originally Posted by LGshow19
(Post 10761258)
Nice stuff!
I understand I was just wondering what was used on the 93 setup...
