Daniel's 855whp SLR2.2 FP3794
A few months ago, Daniel took delivery of his then 821whp Evo 8 to add some fun and excitement to his otherwise dull of life of working in EOD. For those that dont know thats Explosive Ordinance Disposal for the Army. That thread is here-
https://www.evolutionm.net/forums/ev...3-3794-ts.html There were a few things that needed finished that we didnt get to in the initial build like the boost control system and finishing the fuel system. All in all though it did make good power but as the boost dropped out the top power started slacking off fairly quickly. http://img.photobucket.com/albums/v5...ps68ba6510.jpg We revisited the car this week and added a few things that werent there before- A second 3 port to retain the tru boost for quick changes and the 3 port to hold boost out the top, and a full AN full system and rail fed by some bigger pumps. This was on top of the previous mods- ER SLR 2.2 10:1 compression ER Jeff Bush Ported Evo VIII cylinder head w/ 1mm over valves Wiseco 1400HD 10:1 pistons R&R 153mm I beam connecting rods K1 94mm crankshaft Forced Performance HTA394 with twin scroll 1.15 V-Band FIC2150s GSC S3 camshaft set GSC +1mm Valves Kiggly Beehive valvesprings Magnus V5 intake manifold ETS Forward facing turbo kit with twin 38mm MVS wastegates ETS 4" race intercooler w/ 2.5" piping Buschur Racing double pumper 3" Ebay exhaust re-engineered with a Vibrant Muffler and 3" dump Boomba 75mm TB AEM Series 1 EMS tuned by Lucas English E90ish I just got it off the dyno after some quick pulls and got it to make this before the ignition gave up the ghost- http://img.photobucket.com/albums/v5...ps083361fc.jpg To be fair most Non-CDi's have a harder time at this level, but that one misfire made me abort a little earlier than the previous 9k+ rev limit. Boost was 41 peak and only 40 at 8200 where I let off. Looks like the 1.15 wasnt the restriction I thought it was. Here are the 2 overlaid, notice the 50whp gain getting it to hold more boost out the top- http://img.photobucket.com/albums/v5...ps6e9ace82.jpg A full Sparktech CDi ignition and another 4-5psi maybe something even cooler will happen ;) Aaron |
very impressive!!! cant imagine the feeling of that pull on the freeway haha 0_0
Congrats on the awesome build. Was this engine O-ring?
Great build . I bet it pulls more than a freight train. As usual good results coming from English Racing .
Congrats man! The car is an absolute monster. Let's work out a deal for those certs so you can buy a cdi http://images.ibsrv.net/ibsrv/res/sr...e_thumbsup.gif
Originally Posted by 4drboost
(Post 10778874)
Congrats on the awesome build. Was this egine O-ring?
this is really similar to what im doing next. glad you gave it more boost uptop, its definitely a bad mofo. i see 900whp+ after the ignition all day. must feel like being dropped off a cliff every time he pushes the gas pedal down.
It goes from 300-700hp in 1000rpm... I bet that feels sickening... Sorta like a fighter jet... Only with a cooler sounding turbine.. X
Aaron, this thread gives me high hopes for my build as well. I'll keep pinging you with ideas. What a motivator this thread is.
I think a SparkTech Non-CDi would be okay at the boost level we are wanting to run, this particular one was giving up at 40psi. I dont feel it was a timing misfire as we were definitely near MBT and saw some larger voltage spikes occasionally. The spikes could have been the misfire or a smaller misfire. It did good up to 850whp though :)
40 psi and making 850ish is pretty good. I hope to be around this level.
It was 13* according to the AEM but I am not 100% sure that even when sync'd AEM timing numbers are accurate. The look of the power doesnt look like it was low timing, it was 4th gear, and I had sprayed the rollers to make sure I hadnt lost any traction. If I hadnt had the misfire I would have revved it out to 9k but also ran more boost on the next pull as I still had fuel to go.
Guess I need the same ignition or the pro cdi
Aaron, what is the fuel system comprised of?
That is sick. Love that turbo. Any videos of the car on the street?
| All times are GMT -7. The time now is 11:07 PM. |
