evo 9 GSR Stock block & head & FMIC / MAP EF4 93oct @ 29psi
This car put out some really solid #'s for its minimal mods. I really enjoy tuning a car on 93oct when its good quality 93oct. What surprises me the most is how well the car handled it with the stock FMIC. Usually the stock FMIC sucks. If you're trying to make power on 93oct or something similar, the FMIC should be one of the first things you upgrade!
Fuel: 93oct (Pittsburgh, PA) ECU: Tephra v7 SD / Ecu boost Temp / boost: 65-70F / 29-30psi Mods: Stock Block & head Stock cams stock front mount intercooler full ets short route intercooler piping MAP EF4 Turbo (Ported + Thermal Coated) MAP short runner exhaust manifold curt brown ported Megan O2 housing FIC 1100cc injectors Modded walbro 255 Grimmspeed 3 port Tephra v7 + SD / ecuboost Graph: http://www.tscomptuned.net/_images/d...obF/ef4-93.jpg http://www.tscomptuned.net/_images/d...bF/Rob-evo.jpg Thoughts: Car makes very solid power for its minimal mod list. I slowly fed the engine boost as the RPM's went up, and that keeps the engine happy and the torque down at low RPM. I could bump the torque up downlow, but there is absolutely no point in doing so when the customer is 100% satisfied with the results and his vehicles performance as the car currently sits. Thank you Rob for being a great customer and choosing my 1 year subscription service for your vehicle. |
subscription service b/c I bet cams are on order :p
Thanks a ton Tom! I'm sure you spent alot of long nights working on this tune and it shows, you extracted unbelievable power out of this setup. I am very happy with the results, describing the power would be endless power right to redline, the stock turbo fell off quickly in high rpm, with this ef4 is pulls like a freight train. Thanks Tom!
Originally Posted by bitterchild
(Post 10795298)
Great job Tom
solid numbers!
Im suprised it made that kinda power with stock cams, good stuff man
I like ure boost curve. Ive been doing this kinda thing ever since ecu boost came out. And not even for the reason of saving the block. I just like how it feels. A more progressive power delivery. And it keeps the EGTs lower in the mids, allowing a bit more to be squeezed uptop.
Thanks guys, Tom is the ****! Just got my front mount, retune and squeeze a couple more ponies out. After that GSC S2 and springs and shoot for 500 whp stock block!
very good numbers!!!!!
Now do e85 and turn it up higher! You won't.
I'll also be interested to see how long the block will hold up with that much boost. I'm used to Subies where their **** will blow up if they see anymore than 23 lbs.
solid numbers great job !!!!
Man that is some serious power. How would you rate this turbo in terms or reliability vs FP Red vs CBRD BB-K Full?
He installed a ETS 3" FMIC he purchased through me so i will repost a new graph once its done. im going to feed it alittle more boost downlow to get the tq curve to look nicer and funner.
I would of had him do a 3.5" but i didnt find out we did a 3" until it was to late. the 3" should still help substantially over the stock FMIC though. |
