EVO 9 MAP 2.3L MAP Top Mount 6466 GSC S3 E85 43psi 800whp+
This is the car i did the cam comparison test on. i want to split the threads so nothing is confusing. Heres what the car made at roughly 42-43psi. There is more in the car with more boost. We are going to explore that soon. somewhere around 44-45psi we will stop.
Steve emailed me saying that "The car has reached stupid fast status" :lol: I'm sure it feels real nice. Honestly i would probably leave it where it is if it was my personal vehicle, but he wants more. He has history owning fast cars, so i guess i can't blame him. Little hiccup at 5k, i don't know if it misfired there and blew spark or if tires spun, but just noting it. You'll notice the boost curve is controlled a lot. we are trying to keep torque down at lower rpm's to save the tires from spinning. it helps, but it doesn't cure the issue 100%. Looks like i'll have to start adding fuel at higher RPM in the map, which is a sign that its running out of fuel pump. ECU: stock ecu + speed density + ecu boost Fuel: E85 Mods are: Evo 9 GSR MAP 2.3 (Wiseco HD Pistons, Manley TT Rods, Manley Billet Crank) MAP Top Mount Turbo Kit with Precision 6466 Turbo and Turbosmart Hyper-Gate 45 MAP 3" Downpipe, Invidia Test Pipe, Greddy 3" Cat-back GSC S3 Cams (Kiggly Valve Springs and Retainers) Buschur Ported Intake Manifold Buschur Ported 65mm Throttlebody Buschur UICP with Turbosmart Race Port BOV-VTA Buschur Double Pumper ETS 3.5" Intercooler Spoolinup COP Denso IKH24 Plugs- Colder FIC 2150cc Injectors Aeromotive FPR- 43 PSI Base Pressure AMS Fuel Rail Grimmspeed EBCS with larger 1/4" fittings Tephra v7 speed density / ecu boost Graph: (3rd Gear) http://www.tscomptuned.net/_images/d...42-6smooth.jpg Some pics of car again: http://www.tscomptuned.net/_images/d...EnginePic2.jpg http://www.tscomptuned.net/_images/d.../FrontSide.jpg |
Badass!
damn i'm hungy of 6466.
That thing looks hot ! Nice work Tom
rpf1's look amazing on that car. if he gets more fuel its going to make a even crazier number!
Wow this is awesome!!! What size fuel line is he running?
Great results and looking car! Was this done on stock fuel lines?
Originally Posted by 5LEEPERISAH23I
(Post 10832974)
Awesome numbers, hopefully my setup is finished soon and I'll be hitting you up too to see what my car does with this badass turbo |
Originally Posted by talon91guy
(Post 10833023)
More pics can be found here: https://www.evolutionm.net/forums/ev...neak-peek.html |
Car looks mean
Is it possible to crush on car?
ugh... so nasty
So beast, which turbine housing A/R did you get?
Originally Posted by klever
(Post 10833708)
This set up is awesome! Great power made from that tune as well!
Why did you choose to go with a top mount turbo kit? |
