Evo 8 FP 71HTA 93oct 29psi
This little guy surprised me. the FP 71HTA made strong power. temps were around 65F during the runs in Canada. The owner Jean, said the gasoline they get over there is more so equiv to 94oct in the usa, so just thought i'd note that also.
Loc: Canada Temp: 65F Gas: 93oct ECU: stock ecu MAF + tephra v7 Mods are: Stock Block & Head Kelford 264/260 cams with stock valvetrain Spoolinup cop on bpr7es MAP stock ported exhaust manifold FP 71HTA turbo 84 mm compressor housing FP intake pipe + K&N filter ETS licp ETS 3.5 inch fmic ETS UICP (short route with mini battery) PTE 880cc injectors Walbro 255 hp snow performance stage 2 water/meth injection (turned off) ported megan o2 housing 3 inch turboback exhaust Graph with no meth: (Street tune) http://tscomptuned.net/_images/dyno-.../Jean/Jean.jpg Graph with meth: (Road course tune) (coming soon) cars a track / road course car, so we are doing two tunes here. the one i just showed is a road tune for him to enjoy the car on the public street. The 2nd tune i did not post yet. That tune will have the boost turned down to around 24psi and we will richen the afr just a tad + we will enable the methanol for cooling the intake charge even further. The meth won't exactly be fully taken advantage of in this situation, it is more so like just turning it on to give the car a little extra security. Just like someone that would mix some race gas in with their regular gas for example to up the octane to assure they don't get knock during an long endurance event. Will share that graph once i finish that tune. |
Tom do you think the turbo will make 470 with meth ?
I am really interested in this thread I have similar mods.
I will be running a MAP EF2.5 I have S2's instead of kelfords And ID1000 injectors |
Hi guys! This is my car. And because of tom, it push so hard!!! And it run really well, power start at 3500 rpm and never stop pushing! This is exactly what i want, thanks to tscomp.
I don't want to push the car to max power because in the beginning of the year, i blow a bottom end... I know there is there is really low risk now that i had a real tuner... But im still scared so until i forged the motor, i don't want to push the car to hard. We have big winter here, so road course season last only 5 month, its why next year we will push this setup to his limits. Thanks again tom for everything. |
Originally Posted by HsamehH
(Post 10844429)
I will post what it makes on the meth with low boost though once finished.
Originally Posted by Tekniq
(Post 10844442)
Originally Posted by gigitalon
(Post 10844621)
In for results!! Just picked up a 71hta, this is looking promising! Wonder if the 71 and a 2.3/e85 could break the 500 mark..
+1 for the 71.
I always love seeing the threads Where does the map ported stock exhaust mani pick up over the unported version particular with the 71 turbo |
This turbo looks promising and the best part is it is very affordable compared to others out there! I have WMI too so I'm interested to see what it'll do on 24 psi with meth.
hurry up tom :D we are waiting the results
Solid results! How's the HTA71 compare to the BBK Lite?
Originally Posted by evowner17
(Post 10849485)
The 71hta is a bit small for a 2.3 stroker, your torque will peak before you're halfway through the powerband. e85 and big cams will help a bit but only as a bandaid |
Well i have 2.3 with S2's and HTA Green for AutoX the car is little bit slow at low rpm the IX and HTA71 Turbo is very good for tracks.
it depend how you want your car to be,i see the IX and HTA71/HKS GTII is best turbo to perform for track days but for drag and street racing nothing less than green/red/black. |
Originally Posted by bitterchild
(Post 10851740)
Any word on when this car will be tuned on Meth? Excited to see results :updown: |
it would feel like k03's on a 2.7, undersized. Just personal preference. To each his own. Btw, there are a few e85 results for 71hta's by Tom here, search "71hta" title only.
at 24psi it made 400whp so far with a lot less torque. were not done yet. his throttle body seals are leaking or some seal went bad in the throttle body area so we stopped. whenever we resume and i complete it i will share it.
