Nick's beast - Evo 9 MR - 2.1L FP Black FP5R AEM EMS v2 E85 kill mode
We finished tweaking Nicks evo today and we got some really nice numbers given the temps outside. It was around 95F outside in MO, however low humidity in the 30-40%.
This is the first Evo i've done on AEM EMS (Prior only have done S2000's), so i got a lot of help from Nick when doing the car as far as setting up general settings and so forth. With my base map we were able to get the car running well, then from there me and Nick worked together to get the car dialed in really good with setting fuel cut settings, o2 feedback table, misc idle controller parameters, and other misc things. If i remember correctly, we actually started from scratch on a fresh calibration and then fine tuned everything to what we thought was best after we got it all running. The car drives amazing and makes very smooth power. This car will also be featured on 1320vids soon as well. It killed a ZR1 and gave some 1 liter bikes some trouble with the tune maybe 80% complete at the time. Since we don't know what the actual timing of the car is, we left a few degrees uptop conservative, so theres more in the car, but without a dyno its not worth risking it on a road that isn't 100% flat. We didn't sync the AEM with a timing light yet because we didn't have a light to sync it with. Once Nick gets back to OH we will put it on a local dynojet to see what we come up with as well. ECU: AEM EMS Series 2 Loc: MO Fuel: E85 mods: Boston Hatcher Built 2.1L Wiseco 1400HD pistons 10.1 compression MAP ultimate duty rods FP Black DBB Ported /w Turbosmart 26psi WGA Buschur stage 3 head Modded MIVEC Gear MAP H11 head studs FP5R cams AMS FMIC 3.8” AMS LICP and UICP FIC 2150 / -8 Feed -6 Return fuel lines and AN Fittings Fuel Lab Inline 5" Fuel Filter Fuel lab mini FPR Magnus Fuel Rail Buschur COP CDI ignition system Magnus v5 Intake manifold Boomba 75mm throttle body boomba PCV JMF Exhaust Manifold MAP o2 dump with 3d Flange Ebay 3 inch downpipe AMS 3 inch exhaust QTP electric cutout with turn down Full Blown Anodized Fuel Hanger - 2 Modded Walbro 255 fuel pumps Siphon Drilled to 9/64 Quartermaster 8 leg twin disc clutch Tial 50mm BOV AEM Serial Gauge AEM EMS v2 AEM boost control solenoid SD kit omni 4 bar gm iat Graph: http://tscomptuned.net/_images/dyno-...son/Nick-1.jpg Still alittle more tweaking we will do, but the results as is are very nice. it almost has over 4000RPM of powerband in 3rd gear! We are revving out to 9k! https://fbcdn-sphotos-h-a.akamaihd.n...86346543_o.jpg http://tscomptuned.net/_images/dyno-...ck-engine1.jpg |
love the rims! and engine bay is so clean! 9k + 35 PSI = 1 angry FP Black HA!
Good stuff tho car prob RIPS! |
Time for some real tires on that hog. Probably a handful to drive on the street. I know mine was.
Street sweeper looks like fun!
This car should go 140 on tire. I went 133 with a way less top end biased powerband....this should crush on the strip.
I like it. I always found the 2.1L concept to be sexy. Hope his is all he wants it to be.
Nice! This is a clean engine bay. I am liking the AN line to the intake pipe.
very nice work and results guys!
Tom, can you elaborate more about the timming comment you made? "Since we don't know what the actual timing of the car is, we left a few degrees uptop conservative, so theres more in the car, but without a dyno its not worth risking it on a road that isn't 100% flat. We didn't sync the AEM with a timing light yet because we didn't have a light to sync it with." Does AEM not provide a timming feedback? |
^ When setting up the AEM EMS, you need to use a timing light to verify/ match the timing value in the EMS' "timing base map". Once you match the base timing values in the EMS, to the what is reading on the timing light (ie if youre getting 10* at idle, you calibrate your base timing map to that value* in the EMS) your EMS "in synch" with your engines' timing at idle.
This process is a PITA lol After this, your values logged will match, to what is in your timing map. If that was confusing, here is how AEM recommends setting it up. Steps 1. Start your car 2. On AEM Pro go to Configure -> ECU Setup -> Set Ignition 3. Set the fixed Ignition timing in the box from 0 to 10(or what ever value you like that will not kill the car) 4. Check the Box -- This will now have your car at 10 degrees timing based on the EMS, so now you need to sync the EMS and the Car. 5. Check to see where your timing is currently at, with the timing light(You will most likley not have the same number for both the car and the EMS) You want to get the Ign Timing number(10) to equal the value you see on your timing marks -- This is accomplished by pressing the Advance and Retard buttons. -- Corse and Fine adjustment ----Corse = 2+ degrees per Advance/Retard button click ----Fine = .2 degrees per Advance/Retard button click 6. Start with the Corse setting and get as close to 10 degrees as possible, remember to check the timing light after each button click. 7. Now you are very close to 10 degrees, switch to Fine, and repeat until you are as close to 10 degrees as possible. 8. Once you are satisified with where you are at, simpley uncheck the Set Fixed timing, and click the Ok button. |
^Thx your explanation totally makes sense. I suppose the same needs to be done to other aftermarket ecu's as well?
ps. sry Tom & Nick...dont mean to turn this into aftermarket ecu's 101:) |
I'm not seeing 4000+ rpms of powerband???
I'm seeing power start to level off around 7k rpm... and held till 9k? |
Originally Posted by 5LEEPERISAH23I
(Post 10892053)
Good stuff tho car prob RIPS! ya the turbos definitely getting its ass kicked. :lol:
Originally Posted by GotWheelHop
(Post 10892322)
http://thechazz.com/wp-content/uploa...EVO-106-35.jpg
Originally Posted by AngryEvo8
(Post 10892432)
(Post 10892778)
Originally Posted by GPTourer
(Post 10892820)
Originally Posted by detroit pistins
(Post 10893516)
ps. sry Tom & Nick...dont mean to turn this into aftermarket ecu's 101:) I do not know if other ECU's require the timing synch or not, id imagine so. we may be able to feed the car more timing up top and stop it from falling off like it is now. but i dont wanna do that unless we go on a dyno for safety purposes since we're using e85. |
Originally Posted by Craig King
(Post 10893577)
I'm seeing power start to level off around 7k rpm... and held till 9k? just because its falling off up top doesn't mean that isnt part of the powerband. its still over 600whp in the graph. ----------- it actually starts around 4800ish which makes it over 4k here. |
Nice power from a stock frame
Originally Posted by tscompusa
(Post 10893582)
No problem feel free to ask all you want. If anyone wants a AEM v2 right now for evo 8 msg me they are on sale for an extremely low price right now. I do not know if other ECU's require the timing synch or not, id imagine so. . |
