TSCOMPtuned Built & Tuned - Stock Block MAP EF 2.5 S3 93oct @ 21.8psi
I picked this car up from a local customer to do a lot of mechanical work on it. The car was bone stock when I got it and I had added the following performance mods to it aside from a Apexi safc & hallman mbc & an unknown 3" TBE;
Map EF 2.5 turbo ported & coated Map o2 eliminator downpipe dumped open FIC 1100cc injectors Walbro 255 punched / modded Curt Brown 70mm Intake Curt Brown ported exhaust manifold Full blown 70mm TB GSC springs & retainers GSC S3 cams ETS FMIC 3.5" ETS upper pipe ETS lower pipe ETS SD intake pipe Crushed evo 9 BOV Grimmspeed 3 port ARP Standard headstuds Non power maintenance i did was: New Headgasket New timing belt & balance shaft belt New waterpump New tensioner & pulleys AEM Wideband gauge Dimple drain plug magnet Omnipower 4bar map Gauge pod install Ran all new vac lines + zipties + connectors New oil filter New brad penn 10w40 oil Boost leak tested to 25psi Converted vehicle to speed density via tephra v7 Now after all that was done i started to tune the car. This car runs a 3 port and a mbc to keep the boost curve nice and flat. it worked quite well with this car. Not trusting the quality of fuel here i didn't push the car to its max. at 22psi it has a nice top end though. We will extract more later once i drop the car off to its owner and he fills up with his own local 93oct. Overall the setup is very fun. it has low end kick and top end. 1-2nd gear are very responsive still like a stock turbo. It is a very fun setup to drive. I avoided loading it up downlow. The turbo comes on hard if you start at 2000RPM it hit 20psi before 3700. This is something i wanted to avoid since its a stock block. The pulls were done starting at 3100RPM. http://www.tscomptuned.net/_images/d...drew-temp1.jpg difference between the two pulls is outside temperature. it was 20F cooler on the green line. temps were around 50F Before & after of the engine bay: http://www.tscomptuned.net/_images/d...w3/before1.jpg After: http://www.tscomptuned.net/_images/d...ew3/after1.jpg It doesn't even look like the same engine bay anymore! I am very meticulous & a clean freak and dirt doesn't last long around me even if its not my car. - To see more pictures of the car go here. I documented the build as i was doing it on my facebook. https://www.facebook.com/media/set/?...7302897&type=3 And heres a random video i made after firing it up not fully finished (the harness in the video was a jumper harness for the SAFC that used to be in the car). https://www.facebook.com/photo.php?v...type=2&theater Video before loading it on the trailer and delivering it to customer: |
That's awesome! LOL @ before and after engine bay, that's a nice clean up!!
I'm wondering, why S3 cams? Planning to go bigger turbo? |
good stuff! Now put your car together!
First off I'd like to thank Tom for everything he has done with the car and for me. He has gone above and beyond from day one with it! Couldn't be happier honestly. His goal is clearly to serve and that he did. People always say about his attention to detail but this shows it. I literally piled a ton of parts in my car and said have at lol.
Originally Posted by EvoIIIAj
(Post 10994811)
damn clean my bay tom! my ****s damn near like the first pic, what was the best cleaner you used for grime and dirt?
Originally Posted by 5LEEPERISAH23I
(Post 10994815)
AGREED! Cause I'm waitin on his a** to get his together so he can start my build LOL |
that's interesting combo :),good work tom ;)
is this thing gonna get an e-85 tune as well?
Is the hybrid boost control combo only for higher RPM transient response? (like the WGDC 100% under X load table)
I don't see how it is better than Ecu controlled boost if the solenoid is completely shut on spool up. I mean, you can't run more boost than a closed wastegate actuator line. Thanks for the answer ;) |
Good work like always
Thanks guys.
Originally Posted by doober
(Post 10994817)
That and a couple other reasons. I'm not one to do things twice. I knew with the smaller turbo on the stock block I could make some peak power early if I wanted to so I figured why not shift the power band a little to the right. It seemed like a win win for me. It looks like it worked out pretty well up top. All those mods added + it still drives like stock, but with way more response now. its interesting how S3 cams can be so responsive and not hurt low end spool on the smaller turbos, but on the 60lb/min~ turbos they seem to hurt spool quite a bit on 2.0L's. Let me know what you think about the top end. rev it out to 7500 it will surprise you for being such a small turbo. it doesn't fall off uptop.
Originally Posted by mitsubeastlee
(Post 10994819)
Originally Posted by ReignMan24
(Post 10994931)
Originally Posted by needmoreboost!!
(Post 10995964)
Originally Posted by domyz
(Post 10996000)
I don't see how it is better than Ecu controlled boost if the solenoid is completely shut on spool up. I mean, you can't run more boost than a closed wastegate actuator line. Thanks for the answer ;) - Heres the final idle video i took before loading the car onto the trailer and dropping it off to the owner today. As always, i made the SD very nice to drive. i placed the car on a hill and made sure i could take off with very light throttle and not get any kind of lean issues at 1100-1200 ish rpm which SD is very prone to do on evo 8's in particular. |
wd40 it is! i was using lysol it works great but i like the free from rust portion you mentioned now answer me on facebook!
(Post 10995964)
Great work Tom! The attention to detail makes a world of difference.
Tom I am still debating r2 or s3
However it seems like the s3 gives you more peak hp and keeps torque down for stock block. |
