Evo IX The shop built 2.3L Super99 Magnus v5 E85 Wastegate pressure
Im posting this because theres not much results out for this turbo. It sucks because we ran into major fuel issues with this car and had to stop the tuning, so it is what it is here, but it shows the potential of the turbo and the spool is not all that bad as you would expect it to be from a 100lb/min+ t3 turbo. Mivec certainly helps.
Me and Freddy both dialed the car in to drive like stock also with such a big drag setup like this. Its amazing what we can do these days with setups that are so big you wonder how the car can even idle proper. Freddy is a DIY guy and he liked to play around with the tune almost as much as me, so i let him have some fun, and i made final adjustments. While its not a 100% good example of what the super 99 is really capable of, it does show it has great potential. We attempted to turn the boost up behind wastegate pressure and the injector duty cycle instantly surpassed 100% in evoscan. One run around 110%, so we did not proceed further from there on out. We are putting the car back on 93octane and i will share 93oct results with track times. The mod list on this car is as follows: The Shop Built 2.3: Manley Crank, Turbo Tuff Rods and JE 9:1 pistons, ARP Throughout English Racing Stage 3 Head, Kiggly Valve springs, Kiggly Oil Restrictor, New OEM Lifters, GSC stock size Valves GSC S3 Mivec cams\ Modified MIVEC By English Racing L19 head Studs Forced Performance Super99 Turbo Kit, Shearer FF Manifold, Tial 44mm WG BR FMIC W/ All 2.5 inch piping Tial 50mm BOV Custom 1/2 Radiator, STM Fan, 12an fitting throughout Magnus V5 Intake Manifold w/ phenolic spacer Mil.spec 65mm Throttle Body AEM Fuel Rail ID2000 injectors BR Double Pumper: modded Walbro 255 lph primary/ Walbro E85 450 lph Secondary Zeitronix LCD wideband Evo 9 ECU, Omni 4 Bar Map Sensor, GM AIT sensor Sparktech COP CDi12 Ignition BR mini battery kit QM Twin Clutch (older 6 leg version) RRT built Evo IX 5-spd transmission w/ 4.0 Final Drive Shep Stage III T-Case w/ Quaife: Custom 3in V-band exhaust Hallman Manual Boost Controller The graph: Keep in mind AFR is not optimum, and boost creeped uncontrollably to 38-39psi. The red line at lower RPM was caused by shock/motion sensor from SSD protection on the laptop. http://www.tscomptuned.net/_images/d...dy/super99.jpg Heres a closer to final result with 3* less timing then what's shared above. This is also after we turned off SSD shock protection on the laptop. RPM scrambled a tad uptop, and attempted to ruin the graph, but you get the idea. We never added the timing back after seeing it was running out of fuel at this point. This graph has mivec adjustments also, and slight fueling also. http://www.tscomptuned.net/_images/d...nservative.jpg |
Thanks Tom, This was my first time trying remote tuning and I also wanted to try the stock ecu for a few reasons. Tom had good luck tuning my old car after I sold it, so I reached out to him see if he wanted to try my current evo. Tom is very meticulous and knowledgeable of the stock ecu for sure.
I have to say the Super 99 surprised me on how fast it spooled (the 2.3 and Mivec dont hurt). We tried to turn up the boost but the car went lean on a half pull, and injector duty cycle hit 115%. To run the super 99 what Robert at FP built it for I have to upgrade my stock fuel feed and return line LOL. Now back to 93 octane to enjoy the car and hopefully run in the 140 MPH zone at full weight. |
I bet it pulls like a freight train!
gonna be a wild ride! street tuning that is a little difficult i bet...
Originally Posted by Freddy302
(Post 11041838)
I have to say the Super 99 surprised me on how fast it spooled (the 2.3 and Mivec dont hurt). We tried to turn up the boost but the car went lean on a half pull, and injector duty cycle hit 115%. To run the super 99 what Robert at FP built it for I have to upgrade my stock fuel feed and return line LOL. Now back to 93 octane to enjoy the car and hopefully run in the 140 MPH zone at full weight. Thanks for the kind words! |
Just install a inline bosch 044 under the hood on a Hobbs switch. A very easy install compared to doing the full feed and return line. This will at least show if the car needs the line upgrade or that 450 just can't keep up.
I updated the thread with a better graph closer to the end. the only difference is its got 3 deg less uptop (11*) vs the other 2 runs shared.
Mivec tweaked and fuel also. the spool curve is not bad at all it's a huge turbo and its hitting at 5500RPM hard even when not starting the pull until 4500RPM. also 3rd gear which is a major factor in spool. |
Awesome. Just what I was looking for. What kind of a/r is this running? What base fuel pressure are you running? Seems like the car is out of pump, lines will definitely clear it up a bit so would switching to a big external pump and one intake
-8 feed and -6 return line combined with the addition of another Walbro 450 in the place of the 255 will provide the fuel you need on E85. On paper that's enough pump to fuel 1000awhp on a Mustang dyno.
super99 FTMFW {thumbup}
Will you be running the same wastegate spring pressure on 93? Looks very good.
What made you switch from AEM to stock ecu. Its going to be handfull on 93, nevermind on E85.
Originally Posted by Lexus01IS
(Post 11045099)
The Stock ecu is blah.. not for me I have been racing for too long. I like direct control of fuel and precision of timing. At this Horsepower level I don't feel comfortable having to try and trick the Stock ECU. I'm gonna go back to the AEM but the V2 this time since it had even more control then the V1.{thumbup} |
I think for a whopping 24hrs you wanted to keep the stock ecu in there and not go back to the AEM. Then after we talked more i kind of talked you out of the stock ecu without even trying to haha.
I'll still be making some very fast passes on the stock ecu before i remove it in my personal car, but for large setups it is superior over the stock ecu no doubt. more logger resolution, more precise timing increment adjustments, full wideband o2 feedback. The list goes on and on. Email me for v2 if you need pricing. ;)
Originally Posted by lude2evo
(Post 11044005)
(Post 11045099)
