-   Evo Dyno Tuning / Results (https://www.evolutionm.net/forums/evo-dyno-tuning-results-299/)
-   -   Andre's 672whp Twin Scroll S362 FMW (https://www.evolutionm.net/forums/evo-dyno-tuning-results/681157-andres-672whp-twin-scroll-s362-fmw.html)
JohnBradley Jan 24, 2014 10:34 AM
Andre has had us tune his car over the last 3 years or so that he has owned it and it has been a journey alot of us have taken. Stock turbo on pumpgas, stock turbo on E85, and was happy with the 391 it put out on stock cams. This was only fun for awhile though and the bug bit again and off he went. After purchasing some 10.5:1 Wiseco pistons, GSC S2s and springs , Fuel Injector Clinic 1650cc injectors, and the parts to do a motor, Andre moved on to the turbo kit.
Doing something a little different than the rest he opted for a Journal bearing Borg Warner S362. This has the FMW wheel, what we normally think of as "billet", so it spools a little faster and makes a little more power. This was coupled with a forward facing twin scroll turbo kit and used a 1.0 housing.
The results speak for themselves-
http://img.photobucket.com/albums/v5...ps91dbce2c.jpg
We were at 90% IDC even with the BR double pumper so the next step will be 2150s and possibly larger pumps.
Aaron
JohnBradley Jan 24, 2014 10:48 AM
AdamAndEvo Jan 24, 2014 02:23 PM
wish we would have stayed to watch that, looks like it turned out great.. congrats
ILoveAWD Jan 24, 2014 02:28 PM
Thanks again Aaron you worked you magic big time, car did exactly what you told me it would do from the time i purchased those pistons to the time you tuned it.
JohnBradley Jan 24, 2014 05:57 PM
Anytime bro
Drifto Jan 24, 2014 08:23 PM
Aaron, I've been looking at this turbo. How do you think it would spool with 9:1 compression on the corn. As much as I love my TS HTA3076 set up, big turbo fever is starting to take over.
el.guerrero Jan 25, 2014 09:57 AM
@aaron which gear for the pull? 3rd?
is this the turbo?
http://www.full-race.com/store/turbo...fmw-turbo.html
61mm?
thanks.
jeffbeagley Jan 25, 2014 10:21 AM
Nice to see some other folks using this turbo! Great job guys.
For spool reference with ported .91 A/R , 3rd gear and stock motor/head.
Code:
13.2542        4500
13.728        4531.25
14.4387        4593.75
14.9125        4593.75
15.8601        4625
16.8077        4687.5
17.5184        4718.75
18.466        4750
19.6505        4812.5
20.3612        4843.75
21.5457        4843.75
22.2564        4906.25
23.4409        4968.75
24.3885        5000
25.0992        5031.25
25.573        5093.75
26.5206        5156.25
doghouse Jan 25, 2014 11:43 AM
Borg Warner FTW!
vtecownedyou Jan 25, 2014 12:11 PM
very impressive numbers both tq and hp gained
ILoveAWD Jan 25, 2014 05:06 PM
thanks guys
MaLo EvoVIII Jan 25, 2014 05:38 PM
Any plans to upgrade the intercooler?
ILoveAWD Jan 27, 2014 07:14 AM
i will eventually but its ok for now
JohnBradley Jan 27, 2014 03:03 PM
On your 2.3 I think this would build boost even faster and make the same power at lower boost. The compression helps of course, but this I wsa only feeding 15* at 8K so I was keeping it on the safe side. The car sees a lot of trips to Mexico and you know how warm it can be there ;)
is this the turbo?
61mm?
thanks.
That turbo yes. Also 3rd gear on these pulls, it hooked well enough it didnt need 4th to make it work right.
Drifto Jan 27, 2014 08:52 PM
Thanks for the info. Mine is still a 2.0, but I'm hoping the spool difference is negligible between 9:1 and 10.5:1. I know the compression helps power output, but I'm hoping to counter that with my mad fab skillz..;)
