Why you need to do an EGR delete
1 Attachment(s)
This shouldnt come as any surprise since we all know they like to blow the vacuum line off anyway, but do you know how much power you lose when the EGR is open? Even if the car doesnt knock the superheated air is stealing horsepower. Gluing the line on, ziptying it, whatever, are all temporary fixes that need to be resolved.
Since many cars are above 80,000 miles and we have seen the EGR start failing between 80 and 100k it is a good investment to get your power back and keep the motor reliable. Here are the results on a car with 76k miles and the EGR deleted on the dyno- Attachment 274191 Unfortunately I am having a minor issue getting the EGR delete we sell online, but it will be there by monday. A $25 fix for 25whp seems like a pretty good bargain. Thanks Aaron |
Have you noticed any increase in vacuum after removing the EGR? I've noticed my BOV slightly opening under very light throttle after the removal, without changing springs.
Take my money {thumbup} will definitely be ordering this.
Nice information. Thanks, gonna get one also.
you guys have to change some things in the tune with the EGR delete or we will get a check engine light right?
I posted this question in the vendor announcements however this is more of the discussion thread.
I was wondering if this is just the block off plate I ordered from you guys or is this something else. |
Great post. Did a full EGR delete when I put my car together for the first time. Didn't even want to deal with it!
Originally Posted by slowsrt4:(
(Post 11285501)
Yes, and there is a giant how-to thread here on the forum. Pretty easy.
gotcha. there is a general consensus that you get slightly worse mpg with this mod, correct?
Any need for a retune after this?
I deleted all egr on manifold and even tapped the egr port inside runner with a cap to block the flow of heat and oil vapors or what have you and I left the hard line running under the fire wall alone (the line that runs to the gas tank i assume) besides weight, will i see any other benefit by deleting the hardline as well as emissions extras on gastank?
Egr block off plate for $25 will do the trick.all you need is delete some stuff from your ecu for emission test purposes(sorry CA guys).I don't see any decreased millage to be honest.and no you don't need a retune.
Originally Posted by egis
(Post 11285624)
Is there an EGR force inspection in tephra for this delete? In MA we need all sensors working to pass inspection or at least a forced inspection code like i have for the rear o2 sensor. That would be the thing stopping me from removing my EGR.
