TSComptuned BR 2.0L STM FF 6766 GSC S3 E85
This car has already gone:
http://tscomptuned.net/_images/dyno-...ew/4hJhT9o.jpg To set the Holset HX40 bar in the Evo. This turbos popular for DSM's, not to many evo guys were using it. Badev0 had it at one point or another when I was tuning his stock block and we did low 10's at around 140 also. Now we have swapped the Holset turbo for a Precision 6766 Turbo. We did alittle tuning, but kept it rather conservative due to still only having the omni 4 bar which is maxed out at 45psi. The log says 45.1psi, but really these numbers were made around 47-48psi. Since we didnt want to really do this (max the map sensor out), we had to stop it around here around 47psi. What happens when you max the map sensor out is, it uses the last known values and keeps them. So you may end up going a little leaner the higher RPM you go, but it is not as dangerous as it may seem. So temporary we put it on here, and he went to the track. At the track the transmission wouldnt let the car shift into gear so no clean passes, and no consistentency of any kind, other then high trap speed. We both believe/think this car will go 155 as is with a good trans. not being able to shift severely hurts every aspect of the cars performance at the track. If you look at the 1/8 MPH you can see its so inconsistent. Yet the car still kept trapping around 150. Mods are: Buschur 2.0L Curt Brown Head Curt Brown Extreme 70mm Intake Manifold /w Full Blown 70mm TB STM FF /w Precision 6766 GSC S3 Cams ETS 4" Intercooler w/ Short route upper pipe FIC 2150cc Injectors Spoolin up COP Ignition Magnafuel ProTuner 750 Tial Q BOV / Tial 44mm Wastegate Quarter Master 8 Leg KOYO Half Radiator w/ SPAL Fan MAP H11 Head Studs Grimmspeed 3 port Tephra V7 speed density /w ecuboost Few pics of the car. Its a beautiful yellow evo. http://tscomptuned.net/_images/dyno-...ew/KHpD46b.jpg http://tscomptuned.net/_images/dyno-...57483082_n.jpg http://tscomptuned.net/_images/dyno-.../Shootout1.jpg Finally Graph: (Boost was somewhere around 46-48psi) 3rd gear & log stopped at 7968RPM due to 1byte RPM. I wasnt to interested in seeing past that for now since we are limited by the map sensor. http://tscomptuned.net/_images/dyno-.../6766-temp.jpg And 3 slips on the 6766 with major transmission issues. Nothing was clean on any of these runs. Complete lock out of gears. http://tscomptuned.net/_images/dyno-...6766-slips.jpg |
Such as shame, but atleast he's trapping 150mph on a crappy transmission.
How much boost are you planning on running? |
Whats making the Transmission lock out bad clutch or a bad trans?
Deleted.
Originally Posted by Faisalm
(Post 11298967)
How much boost are you planning on running? And of course an 8 second pass. The car also is a little heavy vs the competition, so we will be shaving more weight also.
(Post 11299023)
Deleted.
Originally Posted by thepoint4life23
(Post 11299016)
He thinks that a half dog box trans will get him fixed. The 1-2 is always the problem usually with this car. |
not surprising tranny wont shift with such a high rpm powerband. been a while since I seen tq peak that high. and pooooor clutch!
Love this car, should have no problem running 8's with 55-60 PSI holy hell!
vr-4 on the trailer behind him?
jumping from 10.4 to 8s is a huge jump. lol....
What does the car weigh without driver?
nice setup
Wow. Sick setup!
Originally Posted by AreSTG
(Post 11300238)
Originally Posted by hgp11hockey
(Post 11300624)
Also keep in mind it went 9.7 with a Holset HX40 turbo, and now it has a 6766 turbo.
Originally Posted by wwcagedevo8
(Post 11300837)
