Jason's 2.3L GSC S2 FP Black
1 Attachment(s)
Car is an 03, 431whp/367wtq
2.3L Manley crank, 86.5mm Wiseco HDs FP DBB Black MHI housing Head has some bowl porting by ER GSC S2 cams, Kiggly Springs/Retainers FIC 900s and Walbro 255 Stock intake manifold and throttle body Stock exhaust manifold Open dump Grimmspeed EBCS ETS short route pipes and 3.5" intercooler Tuned on 92 pump only so far until more fuel can be had Attachment 251526 Right now the motor is out. Building it again with a few new parts: Kiggly HLA Eagle 100mm crank Curt Brown 70mm ported intake S90 70mm throttle body FP Cast manifold ceramic coated Ceramic coated turbine housing One-off recirc downpipe Coil on Plug EGR deleted (was disabled, but all hardware was still there) Radium fuel rail and pulse damper I'm doing a bunch of other little things at the same time, and later I'll do a double pumper, 2150s and a FiTronic. Hope to be updating this with new numbers before July, we'll see. |
IMpressive numbers!
Probably no comments because theyre jelly! haha |
Originally Posted by Jessica1985
(Post 11618076)
IMpressive numbers!
How much boost? I would of thought you would of made a little more on a black even though it was only 92 oct .
am i reading that right...25psi by around 4K rpm? must be a nice drive mate...good work !!
Originally Posted by ctfpevoVIII
(Post 11618159)
Originally Posted by wickedep
(Post 11618173)
That is awesome spool, a bit faster than my MHI red on the 2.0L. True shame FP went to a single scroll housing for the 9 turbo's..
(Post 11618279)
Why are you replacing the Manley crank with the Eagle crank? Aren't they both 100mm?
Originally Posted by 4B11AWD
(Post 11618374)
Originally Posted by JRally
(Post 11618274)
24lbs, was set up fairly conservatively as I was daily driving it at the time
24, ER's sensor reads 1psi high. It does spool nice and early though. |
That sounds like a blast for a street car! I hope you make the jump to E85 soon to really maximize potential of that turbo. They are great!
Originally Posted by Sloppy Hachi
(Post 11618601)
That spool is impressive for a Black. Are you using hybrid boost?
Originally Posted by Erik@MIL.SPEC
(Post 11621767)
| All times are GMT -7. The time now is 05:52 AM. |
