Brandon's Evo 8 - Stock Block XS Power 6266 GSC S2 FiTronic 93/E70
Brandon brought his Evo into the shop for a lot of maintenance and upgrades. Instead of writing a book, I'll just make a list of what we did below:
1. Timing belt job 2. Turbo kit installation / custom fabrication 3. Injectors installation 4. Double pumper installation / wiring 5. Ported the cylinder head + rebuilt it with fresh internals 6. Custom lower intercooler piping 7. Ported intake manifold 8. Exedy Twin HD clutch installation 9. FiTronic installation + sensors 10. Fresh HG /w new headstuds 11. Oil Change /w Brad Penn 10w40 /w AMSoil filter 12. Wire tuck 13. Painted ABS Module + more but you get the idea. After we performed all the maintenance, we then tuned the vehicle of course. Below are the mods on the vehicle and power extracted conservatively since this is a high mileage stock block. Mods: Stock block /w 110K TSComp/McCarty Ported cyl head TSComp/McCarty Ported intake manifold TSComp lower ic piping kit TSComp Double pumper XS Power T3 6266 JB Turbo kit 3" turbo back exhaust Turbosmart wastegate Standard ARP studs GSC S2 cams FIC 2150cc injectors Grimmspeed 3 port / Hallman Pro Exedy twin HD FiTronic Flex fuel tune /w 2-stage boost control Power on E71 Fuel & 93oct below - Temps around 65F; https://cimg7.ibsrv.net/gimg/www.evo...c11e11abc3.jpg When working with a stock block the main objective is torque control. That said, I tuned the car based off the curve I wanted, and this is the outcome of that. The end goal was the most HP I could produce without going over 400WTQ. I went slightly over 400WTQ, but not by much at all. Since its so late in the power band, the internals can absorb the power vs being shocked, which will keep the engine happy with straight rods. Picture of Brandons engine bay; https://cimg9.ibsrv.net/gimg/www.evo...4fa31872e4.jpg Here's the final graph after I detuned the car ever so slightly to keep the curve as safe as possible: https://cimg5.ibsrv.net/gimg/www.evo...0326735866.jpg |
good job.
I'd love to hear that test.
Love it! Im surprised it was fed from the head. Did you use Xspower downpipe?
Nice!
Originally Posted by Streetsweeper
(Post 11681090)
With the Fitronic flex fuel kit, is it self adjusting based on the octane rating? Also this can be done on stock ECU?
Originally Posted by evo.matt
(Post 11682314)
Yes its for the stock ECU. We have sold around 50 kits so far. I'll be sharing a few more cars soon with the FiTronics from our shop soon. If anyone is interested in the kits PM me or sales@tscomptuned.net Sometimes I don't respond right away, but I will respond. |
I am installing a xs power hot kit with a 6266 dbb and mouse intercooler and piping kit. I heard some people say run oil feed from the head and some say no it needs to be from the oil filter housing? also did he have to notch his front motor mount bracket on the block side for the turbo?
Originally Posted by moneyhun89
(Post 11687950)
The stock radiator wont work, and the stock fan may not work either. The kit needs a lot of adjustments out of the box. We had to custom redesign the down pipe and so forth. |
