- - Evo 8 basic Boltons tune
(https://www.evolutionm.net/forums/evo-dyno-tuning-results/738619-evo-8-basic-boltons-tune.html)
Superchargedk20
Mar 25, 2017 02:26 PM
1 Attachment(s)
Hey guys just got my evo 8 tuned. It's pretty stock. Ets intake, ets catted test pipe, Invidia downpipe and magnaflow exhaust. The tuner said I need a fuel pump as right before redline it's getting close to max. I'm gona get a bov as well. Small video too
hows it feel? looks like the torque picks up quick! nice job
Bhsj13
Mar 31, 2017 12:40 PM
just fyi, if you bov currently leaks and you replace it with one tht doesnt, you may need a touch up to your tune. but looks good!
Superchargedk20
Apr 7, 2017 10:11 AM
Originally Posted by Bhsj13
(Post 11725692)
It doesn't leak. But been having a few problems lately . I was losing fuel pressure right before redline so he had to taper off boost to keep it safe. We installed a Walbro pump and a greddy bov. After this the car ran pretty bad. Thought it was just the pump running rich.
Drive 2 hrs to the tuner find out I have a huge boost Leak. He tries to scale the map for when I fix the leak. Get it back home. Fix the bov, car runs amazing. Drive it around at wot see the CEL blinking indicating knock. Check IAT they never pass 91-95 degrees even when it's unplugged... weird. Take a thermal gun to the boost pipe it reads 50-55 degrees. Think the company who sold me the speed density kit came with a bunk iat sensor. Hook up a wide band to it. I'm running as lean as 13.0 ....
So now hopefully a new sensor tomorrow and a retune Shortly to fix this. I'm also ordering an aem wide band and boost gauge. I really wanted to stay away from gauges to keep the car more stock looking but it seems I have no choice lol
it almost sounds like the spring is too stiff. mine has no tututu sounds. donrt run WOT with that afr man, you'll blow.
Superchargedk20
Apr 7, 2017 02:35 PM
(Post 11728026)
The bov wasnt closing properly. There was some debris inside. We cleaned the inside and made a custom gasket. Drove it and it was a monster. Just sux, the tuner had to guess with the amount of boost I was leaking . Just way to lean
Superchargedk20
Apr 7, 2017 02:40 PM
(Post 11728026)
