-   Evo Dyno Tuning / Results (https://www.evolutionm.net/forums/evo-dyno-tuning-results-299/)
-   -   Xona 78/64? (https://www.evolutionm.net/forums/evo-dyno-tuning-results/743194-xona-78-64-a.html)
NewEvoGuyInFL Sep 7, 2017 01:46 PM
Xona 78/64?
It is basically the HTA3586 equivalent, anyone have any real world experience/dyno sheets with it on a built 2.0?
Thanks!
LetsGetThisDone Sep 8, 2017 02:43 PM
https://www.evolutionm.net/forums/ev...hp-inside.html
You'll probably spool it about 400 rpm slower. Make a bit less torque/power because of lower displacement.
GotWheelHop Sep 11, 2017 12:47 AM
A bit slower than what mine was. Also have to remember the turbine is bigger than the gt35 turbine used in the hta86. gt35 turbine is 68mm inducer with a 62.3mm exducer. The xona 64mm is a 64mm exducer.....not sure of inducer size. I had full boost at 4900rpm....so figure you'd be full honk in 3rd at 5500 or so.
evo8vz Sep 13, 2017 04:00 AM
used it would just jump to a pte turbo
bros car has one making 540 whp on a 2.3 at 24 psi but from what ive been told wont make as much power as a pte turbo and they do use a 64mm wheel thats why i compare it more to an inbetween of a 6266 and 6466
xona turbo sells just havent been doing well
LetsGetThisDone Sep 13, 2017 08:11 AM
The 7864 would be a 6264. Unfortunately, never really have seen results of any of the Xona stuff on Evo's to make a real comparison. Lots of Euro guys, P cars, and GTR's run them though.
I have the Xona CHRA Red. The CHRA is awesome.
