2.4LR Evo 9 93oct Virtual Dyno Results
3 Attachment(s)
Hello everyone, this is my first post in the forum and also my first thread. I would like some advice and thoughts about my current build. The build is as follows:
Engine 2.4LR Block Carrilo 156mm H-Beam Rods Wiseco 1400HD 86.5mm Pistons Manley 100mm Billet Crankshaft GSC Race Balance Shaft Fluidampr Crank Pulley ΟΕΜ intake manifold ΟΕΜ throttle body ΟΕΜ manifold Evo 8 turbo with 20G compressor & 10.5 Hotside Forge Evo 9 IWG with 18psi spring Tomei V2 Downpipe De-cat Test Pipe HKS Hi-Power Silent Exhaust Greddy intercooler Mishimoto Intercooler Pipe Kit ARP 2000 Head Studs ARP Main Studs ARP Balancer Bolt Head Mild Intake & Exhaust Porting GSC R2 Cams GSC spring & Retainer Kit GSC Zero Tick Lifters Supertech STD size valves HKS Cam Pulley ER Mivec Gear Mod ARP Cam Tower Bolts ARP Cam Bolts Transmission 5speed trans from Evo 6 - Rebuild with Synchrotech carbon synchros ORC Twin Clutch 4.11 Final Drive ECU Link G4+ Fuel AEM 320 Fuel Pump AMS Fuel Rail ID 1050x injectors 93oct Handling Tein Flex Z Project mu 2 piece SCR-Pro front rotors and HC+ pads with teflon brake lines Wheels OEM for now wearing Continental contact 3. Upgrading to Advan RS 17x8.5 wearing 245/40/17 Michelin Pilot Sport 4. The run was done in 3rd Gear, 93oct pump gas. The boost was 25psi and uptop dropping to 20psi probably due to backpressure issues. I also attach the csv file of the log. Next step after the purchase of Magnus V5 and S90 TB, is the purchase of a T4 1.15a/r 6466 TS with a T4 TS Manifold and twin mvs 38mm wastegates. After these, I will try to hit my goal which is around 600+whp or even 650+ on pump gas. Before you ask me why I use pump gas, E85 is unavailable at my country and race gas is not in my thoughts at the moment as it is a DD. However, here we use 98oct RON pump gas which i think it is a high quality 93pump gas in us Thank you :) https://cimg1.ibsrv.net/gimg/www.evo...f09d6a9b38.jpg |
i notice you had 4.11 final. you did correct your VD data for it .. correct?
Needs more wgate preload. tq is delayed badly.
why are you not seeing full boost until almost 5k RPM?
Originally Posted by hutch959
(Post 11806564)
Originally Posted by ExViTermini
(Post 11806566)
Originally Posted by kaj
(Post 11806567)
Keep in mind that the tuning was done on the street and not on dyno. I do not know if on dyno the tuner can set it up to spool earlier
Something isn't right. A 20g on a 2.4 should see peak boost much, much sooner.
Originally Posted by Tuxevo
(Post 11806631)
Originally Posted by ConEvo
(Post 11806619)
Update.
This weekend I tried to adjust the wastegate preload. the preload was far too stiff. Maybe 6 full turns. I adjusted it to 3 full turns and took it for a road test. It seems that it had slightly better spool but nowhere near from what is supposed to spool. Probably the hotside must have cracks. Here's the new loghttps://cimg2.ibsrv.net/gimg/www.evo...42f751f3b4.jpg Regards |
If I may make a suggestion if your going new intake mani, look at something with larger runners to let that 2.4 breath. The magnus is a sweet piece but to small for the 2.4. I would suggest the AMS f1 if you could fine one, or a JMF manifold. The larger ports on the runners will help a ton. Plus it will push the rpm band more to the right some which will help your top end. I am planning on running a JMF drag mani on my car. Good luck with the build.
Your spool is bad. My 2.4LR (gsc s3+ magnus V5+fp black mhi housing) hits 300tq sooner than yours. Is your 2.4LR cam timing spot on?
Originally Posted by MR ArcticC
(Post 11807717)
