What type of power loss will a leaky throttle cause
I have a car on an FP Red car use to pull hard but feels lazy as hell now. I even had to change my VE from being in low 100 to low 90s. Is this causing a big power loss for my VE to change this much?
depends how bad the leak it, you should do a boost leak test.
(Post 11864681)
its a stroker car that went from like 105 ve to 91 ve due to boost leak |
The throttle body seals are a pretty easy install. I made a pressing tool with a screwdriver and some tape. The first time, I bent them and had to reorder new ones :lol:
if that's where you are leaking, then you have a massive boost leak! Those can leak bad. I couldn't hold more than like 3 psi without them letting it all out |
You found a boost leak. You should fix it..
