EVO IX - Stock engine with S362 SXE / WSRD
Tuned by John at Whalen Speed at R&D. Kept the torque pretty low for the stock rods. This is my girlfriends weekend car w/ AC.
Pump E85 Stock ECU w/ SD Sheepy FF manifold Borg Warner S362 SXE FIC 1650s Stock engine (still factory head bolts) FP4R cams Stock Intake/TB We will probably push it further after valvetrain upgrades later on in the year. 555/397 at 27PSI https://live.staticflickr.com/65535/...b06144e7_c.jpg https://live.staticflickr.com/65535/...5eed7df8_c.jpg https://live.staticflickr.com/65535/...a91a1b62_c.jpg |
Very nice flat torque curve. The Evo looks very clean.
I made similar power and graph when I was running the SS FP Black . |
That's great power for only 27psi.
That’s pretty impressive spool for 2.0 , I’m sure the mivec helps some. What’s the flow rating of that turbo, flow more or less them pte 6466? Thanks
nice power. I'm curious about being able to keep ac with the FF kit. any other manifolds allow for keeping ac?
Originally Posted by BluEVOIX
(Post 11873118)
Originally Posted by 2006EvoIXer
(Post 11873122)
Originally Posted by ctfpevoVIII
(Post 11873150)
Originally Posted by [TK]
(Post 11873229)
Is this with the 68mm turbine wheel or larger one? Also, was the dyno run in 3rd or 4th gear.
Originally Posted by 240Z TwinTurbo
(Post 11873236)
Originally Posted by badev0
(Post 11873243)
68mm turbine exducer with .82 AR vband housing. All dyno pulls were in 3rd gear.
Impressive numbers buddy.
Is this the same turbo S362 FMW ? Which oil catch can are you using ? want to see how you have set it up. |
Originally Posted by mines5
(Post 11873803)
Is this the same turbo S362 FMW ? Which oil catch can are you using ? want to see how you have set it up. It's a basic vented can (allstar performance) with two -6AN lines off the valve cover using STM's adapter fittings. |
(Post 11873803)
