Post exact weights of weight reduction you have done!
Once I do my 5 spd swap & Non-ACD t-case the car will be around 2975 with a 1/4 tank of gas & without driver. That's with full interior, AC, PS, ABS, OEM hood & trunk, OEM front cross member & mustache bar, etc. Remember I have an MR also. I still need to send my t-case out to be built & buy a clutch so I can't really be spending $$ on light weight parts right now.
Haha, I can't get myself to remove the dash YET. Tar sound deadening is gone & I cut away some of the mat from behind the dash. There is still probably 2/3 of it behind the dash & I haven't touched firewall mat in the engine bay yet. Damn it Dan, HVAC is not coming out yet!
All the EGR/EVAP sh*t is gone, including the hard EGR line that runs to the rear. I already feel the peer pressure! I know if I stop by your place this week/weekend so I can check out what your working on now & so you can check out my seats, I'm gonna wanna pull my dash out, damn you!
I did my dash bar in 6061 T6 and had my friend heat treat it after welding! under 3lbs. It's in my build thread Fairclough's "SINISTER"
https://www.evolutionm.net/forums/ev...light=sinister
here is my passenger side ABS/Air bag harness. this runs threw the passenger fender
and here it is now ofter some work. this is the corner marker light. thats all thats left.
on to the next side.
That is pretty funny I just pulled the same harness tonight haha. I also pulled the fuse box out in prep to move it inside the car and remove all the junk not used anymore.
