Post exact weights of weight reduction you have done!
Old Jan 25, 2012 | 02:53 PM
  #811
EvoDan2004's Avatar
Originally Posted by evodan2004
im thinking about making a new 2012 version of a weight reduction thread called ''weight reduction 101. tricks, tips, parts, and idea's. i do not know though. its a lot of work i think.
anyways i need some help. notice the 20A yellow fuse next to the black relays. on the box it shows its the music note. i would guess that indicates the radio. that fuse has a red/white wire and a big white wire coming off it. that red/white wire is a few feet long going in threw the fender well into the harness on the A piller. on my factory un toughed dash harness there is no wire mating to the same red/white wire on the fender harness. so i removed it but it just does not make sense to me. any help would be great.
bump back on track.
Old Jan 25, 2012 | 02:55 PM
  #812
redrocket03's Avatar
Mcdonalds chicken nuggets ftw!!!!!! Haha I've ate these things now for 23 years
Old Jan 25, 2012 | 05:47 PM
  #813
03whitegsr's Avatar
Originally Posted by StreetThisEvo
I am doing the same thing. When eliminating the starter relay did you have to jump/modify anything? Or did you just pull the relay and the wiring related to it? I wasn't sure on this one and just left it. I heard it had something to do with one of the clutch switches. I was going to move it into the main fuse box as well but if I can remove it all together that will be even better!
Thanks for the advise!
And why do you still have the yellow ABS related fuse still in your fuse box? I am referring to the big yellow one next to the two fan related fuse/relay?? I removed mine. You don't have ABS correct??
The relay is a normally closed relay and the clutch switch is a normally closed switch. When the clutch switch is depressed by the pedal, it opens the circuit and allows the relay to return to the closed position. To eliminate it, you just need to connect the large wires together like the relay does in the normally closed position.
I still have the ABS, although I'm not getting power for it from the fuse box. I just didn't like the idea of the power blade sticking up waiting to short something out so I put the fuse back in.
As for weight, I'm a fat *** at 180 pounds, I could lose 20 and be at the weight that works best for me. I've been working on it though it's gotten noticably harder to lose weight. I guess it's true what they say about your 30s. Damn it.
Old Jan 25, 2012 | 08:30 PM
  #814
EvoDan2004's Avatar
my chase bay's harness did not have the power steering wire built into it. so i just pulled it out of the stock harness. i do not think its needed anyways
Old Jan 25, 2012 | 08:34 PM
  #815
EvoDan2004's Avatar
now what i will do is connect the driver fender harness back into the car and whatever wires in the dash harness that no longer meet to a wire on the driver and passenger harness's i will remove from the dash harness. i sure hope this works.
otherwise ill be buying a new dash and driver fender harness and installing it without touching a thing.
Old Jan 25, 2012 | 11:36 PM
  #816
EvoDan2004's Avatar
i am an ANIMAL. WTF have you people got me into. here is a minor update.
ok here is all the plugs i pulled off the driver side fender harness/fuse box
and here are the wires from that hanress
today i went inside the car and started on the dash harness. i cut off the air bag connectors and i just followed the cut wires and de pinned them where ever they went to.
here are the plugs i removed
i am not done yet. i need to plug in the driver side dash harness and see what wires i can remove from the dash harness. but this is a good start here.
sooooooooooooooooooooooooooooooooooooooooooooooooo oo do you guys think my car will start??? im skeptical. if this does not work out im just going to buy a new dash and fender harness and leave it alone.
Old Jan 25, 2012 | 11:41 PM
  #817
EvoDan2004's Avatar
o yea. and the weigh savings is a solid 2.1lbs so far. HAHAAH. i better run a damn 9.9 this year
Old Jan 26, 2012 | 05:27 AM
  #818
B.J.@ToxicFab's Avatar
If you don't run a 9.9 (or faster) this year I will kick you in the nuts...seriously...
Old Jan 26, 2012 | 05:35 AM
  #819
IrightI's Avatar
You guys are hardcore! I love it! lol
Old Jan 26, 2012 | 06:37 AM
  #820
badev0's Avatar
You've jinxed yourself like 11 times now
STM drag brake kit:
Stock rotor
New rotor
Stock caliper with pads
Willwood caliper with pads
Stock brake setup (caliper, rotor, pads)
New brake kit (caliper, rotor, pads)
Old Jan 26, 2012 | 06:38 AM
  #821
EvoDan2004's Avatar
BJ cut them off if i cant hit a 9.9s. s%^t the car will weigh 175lbs less and make about another 50hp on E85 then its last glory 10.1 run. i honestly can not figure out why it will not do it now as it sits. it just does not add up.
Old Jan 26, 2012 | 06:45 AM
  #822
badev0's Avatar
You got it in the bag for sure.
Old Jan 26, 2012 | 06:46 AM
  #823
Sounds good...I'll be standing at the end of the track with tin snips...
badev0...nice brake kit! If I was building just a drag car, I would be all over that STM kit!
Old Jan 26, 2012 | 06:49 AM
  #824
badev0's Avatar
thanks man. its not a drag only car, ill still drive it on the street ALOT but just no hard stopping alot or brake boosting
  #825
EvoDan2004's Avatar
thats what i thought when i dropped 50lbs and added 100hp ''93 to 100oct'' and still ran the same 10.3/4s all day
you want to drive it? i sure cant. haha
